Home > Maintenance & Mods (L322) > Won't start after a run |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
Not sure sorry .... Someone here will be able to guide you otherwise RAVE will help. |
1st May 2013 10:15am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
Item 6
1st May 2013 10:25am |
reynolds Member Since: 07 May 2010 Location: great yarmouth Posts: 83 |
Hi is that the crankshaft or camshaft sensor |
1st May 2013 1:01pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
Would it be an idea to get the codes read to try and establish the fault before you carry on changing parts? |
1st May 2013 1:06pm |
@reynolds
1st May 2013 1:26pm |
I need CAMSHAFT sensor |
1st May 2013 2:56pm |
I looked that the manual and it seems to sit underneath the inlet pipe from filter to engine on the UK driver side of the car.
1st May 2013 3:00pm |
1st May 2013 3:16pm |
Thank you |
1st May 2013 4:12pm |
Personally I'd say you need to look at the crank sensor not the cam sensor
1st May 2013 8:19pm |
wslr Member Since: 04 Dec 2011 Location: Wellington, Somerset Posts: 64 |
Most engines will run with a poor cam sensor reading but as mentioned all along, the crank sensor is a critical sensor without which an engine will not run at all.
1st May 2013 10:02pm |
Took it in today to range rover dealer today problem is it needs 3 injectors to rectify starting problem |
9th May 2013 1:52pm |
Sorry to hear. It seems to be the month for the TD6 injectors going MY 2010 5.0 SC Galway green and sand interior!!
9th May 2013 2:22pm |
Cmgrob Member Since: 30 Mar 2015 Location: Northampton Posts: 7 |
Just to throw in my 2p's worth, the cam sensor on the td6 is located under the plastic trim on top of the engine, the diagrams above are from the v8 and located in a completely different place 👍 |
11th Apr 2015 10:16am |
