Home > Maintenance & Mods (L322) > TD6 Turbo - nealry there |
v8 andy Member Since: 18 May 2010 Location: everywhere Posts: 48 |
td6.? good job you did not have a tdV8 theirs 2 turbo's to remove. |
21st May 2010 7:52am |
Just out of curiosity, elpeede, how many miles on your car?
21st May 2010 8:55am |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
77 Thou. I have had it since 59 Thou. nearly three years. I got up real early and got the manifold off having dug out another torx driver. Three studs came out with the nuts from the exhaust manifold. No chance of getting the turbo out with it in situ
21st May 2010 12:52pm |
Todays update...
25th May 2010 7:30pm |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 736 |
Very interested in your adventures as mine will follow as soon as it’s recovered from the dealer for the diff recall and suspension repair. I also have the psst after acceleration and the mechanics all said it’s from the turbo and it is normal. Oh and please post more tips/pictures that help with removal of the turbo. Good luck! |
25th May 2010 9:46pm |
Will do.. though they may be in reverse I was trying to video the removal but the battery ran out on my spy cam I can do a video talking through when partially reassembled I guess |
25th May 2010 10:51pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6349 |
There's several pages in RAVE about the removal of the turbocharger.
25th May 2010 11:39pm |
Exactly, it's mostly the gotcha's I'm after, as RAVE is often detailed about simple procedures and leaves you in the dark in crucial moments... |
26th May 2010 6:38am |
Sounds like School Sex Education lessons! Discovery 4 HSE
26th May 2010 8:27am |
Video of the refit and some pointers
9th Jun 2010 6:45pm |
This is awesome, thank you very much! So I suppose all the problems are gone? No more whistle? No more psst after acceleration? Actually, what causes the psst? I have recovered the car with suspension faults (hopefully) fixed and next week I’ll start looking into the injector and turbo problems. By the way, the engine diagnose showed: P0314 – Cylinder balance control - l-component deviation outside limit. They said this proves injector no. 4 is faulty… |
10th Jun 2010 11:06pm |
Glad to be of assistance... sorry it doesn't include the strip down but as they say... strip down is reverse of reinstallation in this case. The EGR valve can actually be left attached to the inlet manifold.. just undo the jubilee type clamp on the EGR pipe and the vac hose. If you want to clean the EGR it can then be removed much simpler than when the inlet is attached to the engine.
11th Jun 2010 12:07pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Just in case anyone finds this on google, it's an old thread i know, the turbo comes out from underneath as in Rave after removing the complete exhaust from the turbo back as it's only 3 bolts plus the two on the turbo outlet. Very easy to do and no need to remove intake manifold |
10th Mar 2018 4:56pm |
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 |
Yes, a totally overcomplicated way of doing it! |
12th Mar 2018 12:35am |
