Home > Maintenance & Mods (L322) > front wheel bearings |
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 |
has anyone done the front wheel bearing change job at home or is it a garage job ??? |
14th May 2013 9:43pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34959 |
looks like a garage job unless you have a press,
14th May 2013 9:47pm |
Tayas Member Since: 29 Apr 2013 Location: United Kingdom Posts: 74 |
Can you just replace the entire hub? On other cars I've just done that in the past as it's cheaper than getting new bearings pressed in. 2006 FFRR 4.2 Supercharged Vogue SE
14th May 2013 9:55pm |
This is not a "factory made" hub, like I use on my trike where you can't replace the bearing at all. This is a proper (big) bearing pressed into the hub. Replacing the whole hub is possible, just a lot (?) more expensive. MY 2010 5.0 SC Galway green and sand interior!!
14th May 2013 10:11pm |
Deasy Member Since: 26 Oct 2011 Location: Warwickshire Posts: 210 |
I had a front wheel bearing done yesterday at an indie
15th May 2013 7:36am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16187 |
I can sell you the driveshaft pressing tool...
15th May 2013 8:00am |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 |
Do the drive shafts press straight out of the hub, or is there a knack? I recent had my hub and drive shaft out as 1 and the garage couldn't get the drive shaft out of the hub with a press and penetrating oil and 48hrs. Although I have since decided I will not use them again after seeing a gearbox change they done on my brothers van. MY2010 TDV8 Vogue Ipanema Sand
18th May 2013 10:53am |
See my post above! All is explained there... |
18th May 2013 11:01am |
You will probably find you now have a knackered wheel bearing now... They don't like presses and hammers! |
18th May 2013 11:04am |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
I need to change my CV boot gaiters, I think I'll just remove the hub plus driveshaft complete and try replacing them without removing the driveshaft from the hub. Going to beinteresting... |
18th May 2013 11:06am |
Not a nice job rich... Good luck |
18th May 2013 11:13am |
Thanks, I've set aside a day to do it, should be long enough.... |
18th May 2013 11:18am |
