Home > Maintenance & Mods (L322) > flip keys (new order started) |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
I'd be interested in 1
18th May 2013 8:21pm |
Charlie Member Since: 03 Feb 2012 Location: Edgworth Posts: 54 |
Count me in for one of these.
18th May 2013 9:14pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
katash, how many keys do you have at the moment.. V8 facelift Range Rover Autobiography 22" wheels.
18th May 2013 9:21pm |
charlie, i will post a pic as soon as i can.. V8 facelift Range Rover Autobiography 22" wheels.
18th May 2013 9:22pm |
Tayas Member Since: 29 Apr 2013 Location: United Kingdom Posts: 74 |
I'd be interested in one.
18th May 2013 9:28pm |
I have the 2 original late BMW style keys on an early interior facelift car .... I only want 1 key converting as the mrs says her key is fine as is but IIRC the keys are coded 1,2,3 and 4 and you cant have 2 of the same number on the system. Suppose it wont matter even if it is the same number as one of my existing ones tho just potentially could cause an issue if 2 are wanted and are supplied as the same number. |
18th May 2013 10:03pm |
katash, you would use the new key and take the transponder chip out of the old key and put it in the new one, as far as keys 1 2 3 4 nothing will change... V8 facelift Range Rover Autobiography 22" wheels.
18th May 2013 10:09pm |
the EWS unit is what holds all the info about your keys, you need to remove this module so it can be read on the pc, then from that file you can write new keys. the main dealer will not do this for you or even talk about it.. V8 facelift Range Rover Autobiography 22" wheels.
18th May 2013 10:15pm |
Right. So if I wanted one of your keys as a spare, you would be able to do the coding for me if I come to you? I only got the one key with my Rangie and I'm terrified I'll lose it. I was going to go to LR and just drop the £££ on a new key based on my VIN etc. but if there's a cheaper way...... 2006 FFRR 4.2 Supercharged Vogue SE 2007 Honda S2000 2008 Aprilia Tuono Factory |
18th May 2013 10:28pm |
yes, hold five on spnding around 200 pounds and you would still have the old style key from the dealers V8 facelift Range Rover Autobiography 22" wheels.
18th May 2013 10:33pm |
Right you are. Holding. 2006 FFRR 4.2 Supercharged Vogue SE 2007 Honda S2000 2008 Aprilia Tuono Factory |
18th May 2013 10:37pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3641 |
eBay Item No. 261050835380
18th May 2013 11:12pm |
Yep the transponder will need to be switched over but the numbering of keys (1,2,3 or 4) is hard coded into the keyfob not the chip - IIRC its how the car determines the users settings on unlock (seat & mirror position etc ...) My situation (1 key replacement) should be easy to work out if there is a conflict but for anyone who orders 2 - there is a potential that the numbering will be the same and since its not possible to have for example 2 x 'number 2' keys mean only 1 of the new keys will pair. |
19th May 2013 7:05am |
the key number is within the chip, the ewes see's the code coming from your chip and knows what key you are using it will then roll the code on that key, the second part is the circuit board with in the key, this is to open and close your doors, this can be programmed by yourself and is not hard at all but when programming a new key to the car you will need to do all your keys in the same session , yes if I was coding a new key I have up to 10 key positions to chose from, the first 4 are taken by land rover and kept on record, this is how they supply a key without removing your EWS, I can also read your working key and it would tell me what key number it was and this is done so you don’t knock out working keys, land rover will ask you what key you want and if you order the wrong one they will not refund you. V8 facelift Range Rover Autobiography 22" wheels.
19th May 2013 9:23am |
