Home > Wheels & Tyres > Mixing All Season with Winter Tyres |
wackyjim Member Since: 11 Aug 2010 Location: Brigadoon Posts: 2014 |
It may well be safe enough to do as your suggesting but I think anything that could perhaps compromise the safety or handling of vehicle is something best avoided if at all possible...just my opinion |
29th May 2013 12:27pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Firstly, in the summer it probably wouldn't make a great deal of difference, but I still wouldn't do it.
29th May 2013 1:49pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Usual advice is don't mix on an axle.
29th May 2013 4:35pm |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1227 |
I was thinking the same, I can't see much of a difference having winters on the rear and semi winters on the front. As long as the tread depth is good on all corners it will still have grip.
29th May 2013 5:03pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
I went through 2 rear tyres on ns rear in 20k because alignment was out the others had about 7mm on each. I was going to go for 2 cheapies but managed to get 2 x Pirelli part worn tyres with 7.5 mm each on them no damage for €60 euro each fitted so same tyres fitted all round Present :2008 TDV8 HSE
29th May 2013 6:00pm |
I know they can be found and I have no issues with part worns. I just have two spare ice and snow Pirelli Scorpions sitting in my garage and two naked alloys to make the set.... Tom
29th May 2013 6:08pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7760 |
I've come unstuck with mixing tyres and will never do it again
29th May 2013 9:08pm |
I run atrs up front and scorp zeros at the rear without issues and previously ran wranglers up front but they were low on tread. Braking and cornering under extremes was still fine for me.
29th May 2013 9:36pm |
Some great comments, as said in an ideal world we should all be driving with 4 x identical brand new tyres with 8mm tread. But in reality this is not practical, as long as the tread depth is healthy and well balanced I am sure it will not really be noticeable. (and as long as I don't drive it like a Ferrari)
30th May 2013 9:50am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34918 |
afaik the power ratio is 60/40 with the 60% going onto the rear so i would put and keep the deeper thread tyres on the rear.. ... - .- -.
30th May 2013 12:37pm |
The consensus advice is always to put the lower grip on the front axle.
30th May 2013 8:04pm |
