Home > Maintenance & Mods (L322) > Upper Tailgate Corrosion - Repaint or Replace? |
If your car profile was filled in i would be able to offer more advice but the crux of it is its a design fault and if under warranty would be fixed, outside of warranty its a strip and repaint job FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
20th Jul 2013 7:54pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6715 |
If your car is less than 6 years old, then the anti-corrosion warranty should cover replacement. I had mine done earlier this year for the very same thing. Got - 2017 SDV8 Autobiography in Loire Blue
20th Jul 2013 7:58pm |
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 |
Had mine done too, under corrosion warranty.
20th Jul 2013 8:32pm |
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 |
Me too but mine's still in the 3 year surface corrosion warranty. A couple of very small paint blisters, only just visible but no quibble from LR as its a very well documented failure. New door fitted and wax oiled to prevent the same happening again. 4.4 TDV8 Vogue Baltic Blue MY11 |
20th Jul 2013 10:34pm |
Hi, an update:
23rd Jul 2013 4:16pm |
I'd be inclined to ask them to check the weld seam at the bottom of the upper tailgate. This is the area that corrodes and triggers a replacement of the entire upper tail gate assembly (under the 6 year anti-corrosion warranty). Got - 2017 SDV8 Autobiography in Loire Blue
23rd Jul 2013 4:20pm |
Thanks, I presume you mean the same type area as indicated on the above image?
23rd Jul 2013 4:24pm |
That's the very thing. From my limited knowledge, this is never repaired, but always replaced. I'm guessing they're hoping to fob you off by a cosmetic repair, when, in fact, there's something much more sinister going on inside the door cavity.
23rd Jul 2013 4:32pm |
That's great/ I'll have a look and try to get my facts straight.
23rd Jul 2013 4:40pm |
I'd be surprised if they weren't aware of this issue, but if the entire top half of the tail gate is replaced under warranty then it's less for them to shell out I would have thought? Got - 2017 SDV8 Autobiography in Loire Blue
23rd Jul 2013 4:42pm |
Hi, spoke with main dealer service advisor today who said their plan is to sand down and repaint the affected tailgate area.
25th Jul 2013 10:08pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Hi.. It would be good if you could edit your car profile so we know the type of FFRR you have and more importantly the age, as the 6 year corrosion warranty is kind of key to this thread.. Previously..
25th Jul 2013 10:40pm |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 863 |
Cleaning won't help. The rust comes from water sitting inside. They should waxoyl inside the drain holes after painting which should help to prevent return. My Previous RR's!
26th Jul 2013 5:54am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3763 |
I've got e related question having just had mine done, not under warranty ( just outside the 6 years so I didn't even ask ) but what can be done to prevent a recurrence. I suppose what I really mean is where does the water get in and what can be done to prevent or reduce the ingress - the drain holes must be there for a reason? Geoff |
26th Jul 2013 7:06am |
