Home > Technical (L322) > Tow bar |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 |
First of all welcome Smithy313.
26th Jul 2013 6:25am |
They are fundamentally the same however there is a slight difference in the mounting brackets for the exhaust, cant rember when they changed it though. Have a look at pfjones website to see when the changeover date was.
26th Jul 2013 8:38am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6355 |
The two towbar models are for 2002-2005 and 2006 onwards.
26th Jul 2013 8:40am |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 |
Welcome Smithy313,
26th Jul 2013 8:42am |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3076 |
Smithy, The flanges for mounting the exhaust support moved from the 2006 on. Your 2004 version will need some new ones welding onto the armature. I have a almost new (never been mounted) armature for a 2006 onwards and a new (with key) removable tow bar and neck if you are interested. Photos are in my gallery. Pm me if interested. |
26th Jul 2013 10:56am |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
Hi Smithy -
26th Jul 2013 12:10pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2030 |
i bought my FF with the 'farmers' type 3 position hitch, which dragged on the ground when loading onto a trailer, (quite badly) it looks awful too. but when i got hold of the removable type i saw why it was still on there. because it was properly rusted in. it wagged a bit, when as tight as arseholes, so would have been 'strange-noisy' when in use, but no amount of tapping, or thumping would shift it. soi i borrowed a pair bottle jacks, and jacked against the tow 'bar' itself. off it came. and in went the removable type with the pin in in seconds. if you were to coat it in plastic i'm sure you would never get it off again! or even in enough to put in the pin! incidentally, i made up a 4 bike rack to go into the 2inch hole and it works a treat! |
27th Jul 2013 8:58pm |
Smithy313 Member Since: 25 Jul 2013 Location: West mids Posts: 3 |
Thanks for all the replies, the price of the tow has gone up and if I've got to weld the exhaust brackets in a different place and get it re-powder coated, I might as well get a new one, have got one priced up and it's quite reasonable. |
28th Jul 2013 6:18pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7813 |
Quite reasonable doesn't sound right for a FFRR tow bar
28th Jul 2013 6:28pm |
Something like this one, smithy ? . . .
28th Jul 2013 6:52pm |
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 897 |
how do you work out which one that you need and what are the options? i would like to get one but i dont know what the options are.... apologies for being a muppet.... i like the ones that you can put the hitch on and off? |
30th Jul 2013 11:18pm |
it depends what you want to do with the bar? tow or tow and bolt on cycle carriers, or anything with a flange plate adaptor such as old style caravan stabilisers.
30th Jul 2013 11:41pm |
i think that i want something that will allow me to tow but also allow me to add a cycle carrier or one of those thule boxes i have seen that can go on a tow bar..... so which won would that be? |
31st Jul 2013 8:27am |
@Andyleeds
31st Jul 2013 1:54pm |
