Home > Wheels & Tyres > General Grabber AT invalidate insurance!!!!!
Page 2 of 3 <123>
mzplcg
^^ +1.
Size, load rating, speed rating are all in the handbook I seem to recall. There is no mention of brand or type though, that would be illegal for LR to insist on a specific brand.
When you consider that dimensions and ratings can all have an effect on handling/performance/safety I don't think anyone is being unreasonable in having minimum standards, including insurance companies.
And yes, non-standard would include incorrect sizes, load ratings etc and these would be deemed illegal if you got pulled over unless you were able to demonstrate that they exceed the minimum specifications provided. That's very hard to do with odd sizes. Load indices are easy as a would be a speed rating but sizes are a relational thing which induce stresses into the suspension, wheel bearings etc etc. All a bit subjective and a very good reason to avoid things like 22" wheels from the likes of Khack or O/F.
Post #209347 10th Sep 2013 3:08pm
crookedm
2007 Range Rover Vogue SE TDV8 Java Black
So I should ditch these?
275 /45 R20's (110) and go for 255/50/20 ? Must be cheaper ?
Post #209348 10th Sep 2013 3:55pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Has anyone experience of an good AT tyre in that size i.e 255/50/20
Thanks 2013 L405 Autobiography Baltic Blue
2007 L322 Vogue Buckingham Blue
Post #209349 10th Sep 2013 3:57pm
Marbellaboy
United Kingdom 2007 Range Rover SE TDV8 Java Black
Wow some great replies, I get what everyone is saying about the recommended tyres. I have driven a fair few RR's over the years and lots of other big powerful cars, however, there is no decent AT tyre for the 20 inch rim. I currently have 255/50R20 Yokohama's on there which were ok for the use at the time but no longer. I have driven this particular TDV8 at 135mph and believe me it had more to give!! So I understand the speed rating. My needs have changed I need a decent tyre that will deal with wet, muddy roads, we get a lot of surface water around here, ice, snow and the odd trip into a muddy field for shooting. (I got stuck last year with Yokohama's Embarassed ). So is it ok to put a 275/45 on a 20 inch rim that LR recommend a 255/50?? Gone: 2005 4.4 Vogue (LHD) Java Black
Gone: 2002 4.4 Vogue (LHD) Java Black
Gone: 1998 4.6 HSE (LHD) Blue
Gone: 1998 4.6 HSE (LHD) Green
Gone: 1997 4.6 HSE (LHD) Silver
Gone: 1996 2.5 DT (LHD) Green
Gone: 1995 4.6 HSE (LHD) Blue
Gone: 1995 4.6 HSE (RHD) Green
Gone: 1995 V8i Discovery (RHD) Blue
Plus a whole host of normal cars!!!!!!!
Post #209353 10th Sep 2013 4:15pm
yes ,a 275/45/20 tyre will fit ...
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #209354 10th Sep 2013 4:19pm
crookedm
I'm lost! So it fits but isn't insured?
Post #209356 10th Sep 2013 4:23pm
in theory, correct... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #209357 10th Sep 2013 4:27pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
If you're bothered, check with your insurer. Simple.
Re 135 mph in an L322 TDV8 - delimited?
Post #209358 10th Sep 2013 4:28pm
Vogue
exactly ! Thumbs Up
@crooked, 275 45 20 General AT fit fine - absolutely no issues at all
@ Stan, the tyre calculator is fine for std 275 45 20 tyres. However for the General AT's the tyre size of these is exactly the same circumference as OEM, I measured them and put it down to the extra tread depth of the AT's. Therefore there is absolutely no difference in speedo readings over standard. Thumbs Up
@ Rosco there are no 255 50 20 in AT at all, if there were I would have fitted them instead of the 275's Thumbs Up 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #209359 10th Sep 2013 4:34pm
I think it is less a fitment issue and more of a requirement to inform your insurance to put a note on the policy that you are using the different size, they will let you know if they arent happy, and best to discover that first rather than after a prang.
In terms of performance so long as the load and soeed indicees are as quoted in the handbook you will be fine. There is nothing that can't be fixed with a hammer😜😜
Post #209361 10th Sep 2013 4:38pm
Philip
... and assuming the width of the tyre is correct in relation to the wheel its going on, aspect ratio isn't wildly different etc.
Lots of variables, all of which will affect the way the car drives to a greater or lesser degree - extremes will be more of an issue nowadays considering calibration of DSC, roll stability control, active anti-roll bars etc. on OEM tyres.
Post #209362 10th Sep 2013 4:50pm
Rosco
@Vogue, i'm with you and will fit them, any insurance issues can be dealt with, i.e. reasonably, its not a supercharger and nitrous Very Happy 2013 L405 Autobiography Baltic Blue
Post #209387 10th Sep 2013 6:48pm
Vogue
Just slightly off topic but insurance related. For those of us that use our vehicles off road - particularly in the shooting season when ground conditions can be pretty bad / wet and slippy you need to check that your insurance covers you for off road use.
Many do not - hence why their cover is cheap. I know for a fact that NFU do cover you. I would be more concerned about that than a minor deviation in tyre size. Thumbs Up 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #209401 10th Sep 2013 7:47pm
Rosco
Agreed, mine is off road 80% of its time towing and other stuff, so as long as insurance know then no problems as yet. I agree if you are onroad most of the time there me be an issue, Smile 2013 L405 Autobiography Baltic Blue
Post #209407 10th Sep 2013 8:06pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
If they are speed rated above, say, 100mph and one provably does not exceed that speed, is there an issue?
Post #209439 10th Sep 2013 9:43pm
Page 2 of 3 <123>
