Home > Technical (L322) > Another Windscreen Heating Question
shalz
Kenya 2011 Range Rover Vogue TDV8 Santorini Black
Hi all,
I've searched forum but couldn't find anything on this. When switching on the windscreen heater (if frost on the screen), do people find that a small vertical section right in the middle of the windscreen stays misted/frosted for a bit longer than the rest and then eventually clears up?
Could this be due to the heating elements working from outside in or have I got a faulty element in the middle?
forgot to mention that this is the second windscreen on the car, the first being replaced due to stone chips so if this is not normal, could be that the heating elements not connected properly MY11 Vogue 4.4 TDV8 - "African Queen"
Post #224566 22nd Nov 2013 3:18pm
NKSC
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
My new windscreen does this too.
Post #224569 22nd Nov 2013 3:22pm
Andy
Mine only clears on the passenger side. I'm told there are two fuses- one for each side. Anyone confirm this?
Post #224630 22nd Nov 2013 7:22pm
Sparkylee
2003 Range Rover Vogue 4.4 V8 Epsom Green
Not had to use the FFRR one yet but my 110DC defender has the middle line Thumbs Up
Post #224640 22nd Nov 2013 8:22pm
The heating element is in two parts and they dont quite meet in the middle. Perfectly normal. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #224645 22nd Nov 2013 8:42pm
wealy
Yep
That's correct!
Post #224668 22nd Nov 2013 9:57pm
shalz
Thanks all, huge sigh of relief for a change. This forum is tops! MY11 Vogue 4.4 TDV8 - "African Queen"
Post #224708 23rd Nov 2013 2:14am
If you look very closely from the inside you can see the element nes in the screen... You will also see there is one or two missing in the middle hence your question... Thumbs Up
Post #224727 23rd Nov 2013 10:04am
shalz
Thanks Craig. Took a look this morning and see what you mean. Should have looked more closely.
On a separate note I know I'm due to call you and will do so soon once I've got my timings sorted. MY11 Vogue 4.4 TDV8 - "African Queen"
Post #224826 23rd Nov 2013 7:39pm
vogue man1
United Kingdom 2003 Range Rover Vogue Td6 Zambezi Silver
front screen
my screen dont work at all and cant seam to find out why unless the screen is damaged its the same one that came out for the factory in 2003...... Life to short for all the b### ###t
current drive
1 FFRR L322
5 Discovery 4
4 Range Rover L494
3 Range Rover L405
3 Range Rover Evoque
3 Freelander
6 Defender 110
Post #224888 24th Nov 2013 9:00am
