Home > Maintenance & Mods (L322) > egr |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
Certainly is. |
27th Dec 2013 5:09pm |
greasemonkey1 Member Since: 22 Sep 2013 Location: london Posts: 157 |
. thats correct ... enjoy the mod... |
27th Dec 2013 6:05pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6400 |
How are you going to blank it ? .
27th Dec 2013 7:28pm |
wats39 Member Since: 08 Jul 2012 Location: fife Posts: 77 |
Left the egr in place on mine, although i did remove it to clean all the carbon out of it and made sure the valve was fully closed. Put it back on but left the vacuum tube off and blanked the end of it. Does the same as the removal kit but cost nothing . '04 td6 se
27th Dec 2013 8:16pm |
Steverr Member Since: 27 Oct 2013 Location: Bristol Posts: 191 |
With the blanking kit I bought |
27th Dec 2013 8:21pm |
Wish I knew that... wouldn't of bought the blanking kit !!!! |
27th Dec 2013 8:23pm |
On the plus side though, at least you wont have to clean all the out of the egr. '04 td6 se
27th Dec 2013 8:33pm |
Thought you may have found a shiny metal disc of suitable size to poke in the end of the exhaust gas inlet
28th Dec 2013 12:47am |
The valve should be closed when there is no vacuum Joe90 so yours must have been stuck open. Not surprising though with the amount of carbon you find in them. I gained around 2-3 mpg after disconnecting it. Also got peace of mind that the engine isnt breathing in all the carbon too. '04 td6 se
28th Dec 2013 6:28pm |
How long does if take to do ? Also did you use fire gum on the blank off bit. Can I use silicone ? |
28th Dec 2013 8:46pm |
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 |
less than an hour including tea and a bacon roll..............its a very straightforward mod happy to help if you want a trip down south |
28th Dec 2013 8:53pm |
about 20/30 minutes done unrushed,,i used gum gum as that is well known for its reliability when it comes to blocking out exhaust fumes.. |
29th Dec 2013 7:43pm |
