Home > In Car Electronics (L322) > Solar Trickle Charge |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
I hope they've improved. The early ones didn't produce much of a charge. Is it worth investigating a kill switch to isolate the battery during long down times? |
16th Feb 2014 7:31pm |
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 |
I have two in mine, from Maplins, they both sit either side in the rear window via the suckers provided, i then bought a two into one connecter with a cigeratte light plug into the cubby box, this gives a good trickle charge when not used for a while.
16th Feb 2014 7:38pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
This is what I used if I was not using the car for a while.....
16th Feb 2014 7:50pm |
Crikey, what's the output on that one then CB ? Hardly a "Trickle" surely ? |
16th Feb 2014 8:25pm |
this thread now has the risk of becoming mine is bigger than yours
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 |
contraband
16th Feb 2014 8:27pm |
16th Feb 2014 8:35pm |
Cheers buddy 2020 Porsche Panamera Turbo Hybrid (V FAST)
16th Feb 2014 8:41pm |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 |
I do like that one from map links but I've got heavily tinted rear windows will it be effective enough with the tints? |
16th Feb 2014 10:23pm |
The new ones just need light, not necessarily sunlight.... My fatty had drug dealer window tints and it still gave 18v.. Previously..
16th Feb 2014 10:27pm |
Cheers dude I'm off to maplin tomorrow |
16th Feb 2014 10:34pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Apparently you can link up to 10 of them together mm hybrid anybody Present :2008 TDV8 HSE
16th Feb 2014 11:47pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1663 |
Do you have to unplug them before you start the car. Maybe not an issue but you'd have to open the boot and do that before you drove away..? Ash
18th Feb 2014 9:28pm |
I always unplugged mine before I started the fattie... But I only used it if the car was not in use, so it was not an issue. Previously..
18th Feb 2014 10:36pm |
