Home > Technical (L322) > tdv8 metallic whine |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
agreed , nobody wants to spend loads on repairs but you don't have to get the garage to do the job only to find out what the problem is.. ... - .- -.
3rd Jul 2012 12:09pm |
Olders Member Since: 17 Mar 2011 Location: Suffolk Posts: 115 |
The gearbox one is, I believe, only available from a dealer, so I assume the ECM is as well.
3rd Jul 2012 1:05pm |
zippy69 Member Since: 03 Jul 2012 Location: United Kingdom Posts: 2 |
I also have hard acceleration whine but only seems to be in D and not S, any clues ? |
3rd Jul 2012 2:54pm |
I also, sometimes, get a whine under HARD acceleration, however, as far as I am aware, it is only when accelerating hard out of a corner and there is still some steering angle dialled in. It has always been there and thus I assumed it was normal. Perhaps not? -----------------------------------------------
3rd Jul 2012 3:00pm |
For the sake of clarity, this is not the noise I have been talking about earlier in this topic.
3rd Jul 2012 3:03pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
Is the vibration most apparent between 30 to 50mph? |
3rd Jul 2012 3:34pm |
It is rev related rather than speed.
3rd Jul 2012 4:16pm |
I was talking about the first noise atc spoke about which I first encountered yesterday , I have drove about all of today in S and now no longer hear it in D when I tried again , so god knows what it is , will be keeping an ear open from now on to make sure, it was most noticeable coming off circles and accelerating away coming in about 2000 revs right up to gearchange, but as I say it has dissappeared now ???? |
3rd Jul 2012 7:52pm |
Benfelrr Member Since: 27 May 2012 Location: Wiltshire Posts: 279 |
Not wanting to cause heart attacks etc. I had a deep rumble / drone as you suggest and it was a failing diff, my car is also a 2007 TDV8. Hopefully yours is different and something else. Not sure how easy it is on these to do as I got a dealer to look at mine but if you are able to have a check of the front diff oil see if it smells burnt , odd or has swarf in it. If not that doesnt help much but if it does, it might point to a diff issue. Good luck either way. |
24th Oct 2012 12:16pm |
Benfelrr - was your noise right across the rev band or just within certain rev limits?
24th Oct 2012 1:58pm |
Sorry for the delay, have been away, yeah the noise was across the rev range, once the car was moving at any speed the rumble appeared and stayed there, was more pronounced under heavy acceleration. I did read a post on here at the time where someone else had said they were told they had a failing diff and the owner did not believe this and took the car to another dealer who diagnosed faulty transfer box. Good luck getting it sorted, at least diff sounding hopeful. |
29th Oct 2012 9:31am |
Have driven another two tdv8s as well as mine and they all make this wine under hard accleration with bit of turning, so will stick my neck out here and say I guess it must be normal. |
29th Oct 2012 9:44am |
Halk Member Since: 23 Feb 2014 Location: Greece Posts: 5 |
Hi there,
23rd Feb 2014 11:54am |
Hi there. In sime answer..... No!
23rd Feb 2014 4:03pm |
