Home > In Car Electronics (L322) > Generation 5 bluetooth ulf |
There are 2 (or 3?) pairs wires going from the 54 pin connector to the BM radio module - check the wiring diagrams in the RAVE. Unplug both the 54 pin connector and the BM connector and check for a connection with a continuity tester.
6th Mar 2014 2:43pm |
jeffridj Member Since: 27 Nov 2013 Location: Wales Posts: 29 |
I was pretty careful repinning the 54 pin plug but will recheck tomorrow.
6th Mar 2014 11:20pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7631 |
I'll have to dig out the chart I used and check for you.
6th Mar 2014 11:35pm |
Checked all the wiring and it was correct according to the re-pin charts.
7th Mar 2014 3:08pm |
Well thats a pain.
7th Mar 2014 6:04pm |
Yeah totally agree.
7th Mar 2014 10:00pm |
Zaskar Member Since: 17 Mar 2014 Location: Oxfordshire Posts: 18 |
Hi there,
29th Mar 2014 1:52pm |
There is nothing to stop you fitting it all without the aerial.
29th Mar 2014 2:11pm |
Thanks MrJ,
29th Mar 2014 2:29pm |
I thought the rewire would involve me soldering all the pins together, followed by me setting fire to the car.....
29th Mar 2014 2:35pm |
The problem is that i don't have the 54 pin connector to the white block adaptor.
29th Mar 2014 2:42pm |
Ah........
29th Mar 2014 2:53pm |
The white block is in the back and the 2 connectors, one under the cup holder in front of the centre console and in the roof lining are all there.
29th Mar 2014 3:05pm |
If it were me, I'd just connect the x5 loom into the white plug in the boot to get the 54 pin connector. I'd use nothing else from it, if indeed there is more loom with it.
29th Mar 2014 3:16pm |
