Home > Maintenance & Mods (L322) > HOWTO: TD6'02 FFRR "Changing" Glow Plugs |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Since I have had the car (5 years +) diagnostics have always thrown up a glow plug relay code, but I have never done anything about it as everything has been working fine. This year, @ December 2013, the car started to take longer to start, several turns of the starter motor instead of almost instant start up. So I checked the relay, and there was a nice big click/clonk when the ignition was turned to start the car. So I then had the relay connector off and tested the juice to each of the glow plugs. No juice running through 4 out of the 6, so this seemed the likely problem (although others had pointed to fuel problems, but car was running well aside from startup). New glow plugs duly purchased from Dan @ Duckworths @ ฃ16 a pop ( I did find cheaper afterwards on the bay of e ). I have included extracts from RAVE to assist with instructions and visuals (my efforts at taking photos down the back of the engine were pants!)
9th Mar 2014 11:15pm |
Inlet manifold off in a jiffy this week, and raising the bonnet to service mode helped a bit too (no more bumps on the head and better access over the wing)
16th Mar 2014 7:51pm |
I sourced a left handed 7mm tap and some 7mm left handed bolts from eBay (China via Australia !) and decided to do a test run on the bench.
That's the plan, hopefully on order a left handed tap and some left handed bolts, a tungsten carbide drill and burr to get the broken off extractor out. The easyouts have their place, but it is not for things in tight! .
16th Mar 2014 10:07pm |
There is nothing that can't be fixed with a hammer๐๐
16th Mar 2014 10:12pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34929 |
excellent write up Tim [as usual ]..........wiki'fied. ... - .- -.
16th Mar 2014 10:16pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
Pity about the broken extractor but your pictures show just how much oily c p the egr system introduces into the inlet manifold and beyond. Makes you wonder who dreamed up such a stupid idea to assist in reducing exhaust emissions.
16th Mar 2014 10:24pm |
arron Member Since: 22 Sep 2010 Location: lincolnshire Posts: 123 |
can i offer some advise, if you start the engine and leave it to idle to get the engine up to temp without the manifold on then try and remove them. when i did mine they all where flexing and felt like they where going to break until i ran the engine up to temp then they came out nice and easy. |
16th Mar 2014 11:41pm |
@ nicedayforit
17th Mar 2014 12:29am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Ya see Joe, everyone thinks my job is easy...
17th Mar 2014 1:10am |
I'd have to get a TDV8 first .
17th Mar 2014 10:26am |
FFRR 1 - 0 Joe90 .
13th Apr 2014 3:04pm |
yorkie3259 Member Since: 29 Apr 2012 Location: Bridgwater Posts: 9 |
Hi Joe did you ever remove or are you still running with reduced glow plugs.
19th Mar 2017 4:03pm |
@ yorkie, nice colour.
19th Mar 2017 10:36pm |
