Home > Technical (L322) > HELP - misfiring and cutting out....experts baffled |
Winchester101 Member Since: 13 Jun 2013 Location: Essex Posts: 236 |
This might be a bit late but where did you buy the petrol
12th Apr 2014 9:06am |
ALEX1 Member Since: 11 Apr 2014 Location: liverpool Posts: 5 |
No its not the petrol as i have filled up several times by now from different places. I am guessing that it could be the fuel pump but dont know how to narrow it down |
12th Apr 2014 9:12am |
I take it they plugged it in? There is nothing that can't be fixed with a hammer😜😜
12th Apr 2014 9:27am |
The car has left the service garage 3 times now running fine - but after a few days the problem appears as if its something that just builds up with use.....but i cant figure out what |
12th Apr 2014 9:34am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
I think the AA man may have been right... It takes 75 miles for the engine to fully learn new adaptions and if the garage reset the adaptions then it would behave for a few days...
12th Apr 2014 11:50am |
The camshaft sensor has been replaced but the problem pessists. |
12th Apr 2014 12:13pm |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 416 |
If the fault persists then maybe a wiring issue up to the sensor.
12th Apr 2014 2:16pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2543 |
I would check instrument cluster, sounds daft but that was my issue, needed to be replaced and apparently only by a main dealer |
12th Apr 2014 3:31pm |
Is it definetly not a fuel pump issue? Why does it run ok when the mechanics have had a fiddle with it and then start playing up a few days later? |
12th Apr 2014 3:43pm |
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 137 |
Hi ALEX1,
19th Feb 2017 11:38am |
andrew-a Member Since: 07 Sep 2011 Location: Wirral Posts: 70 |
My local garage could not diagnose it so ended up having to take it to the main dealer. It was the fuel injectors - 4 out of the 8 had to be replaced. Dealer quoted £2k for the job! Yikes! |
19th Feb 2017 12:05pm |
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 |
I find setting the cruise to approx 59mph has them reset in about 20 motorway minutes 45 minutes idling will clear any that don't reset after that . Having injectors tested and ultrasonicLly cleaned has worked for me in the past as an alternative to replacement |
22nd Apr 2017 8:28pm |
