Home > In Car Electronics (L322) > Fitting hybrid tv tuner HELP! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34939 |
that part number should be ok, try pressing auto to store some channels..
8th May 2014 12:42pm |
Dr Meat Member Since: 24 Mar 2014 Location: england Posts: 23 |
Does it matter that it has an extra green plug thats not being used? |
8th May 2014 1:04pm |
dunno, i've never fitted one but do a search and you'll probably find an answer .. ... - .- -.
8th May 2014 1:19pm |
8th May 2014 1:20pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
Don't worry about the extra green plug, it's not needed for the TV Tuner to work. Make sure that your location is set to United Kingdom on the settings menu and set to PAL not NTSC. Also, you may find that your in a location where the FF antennae can't pick up a decent signal, so you may need to have a drive around to get a picture.
8th May 2014 2:59pm |
Thanks for all the responses
8th May 2014 3:19pm |
so it works when the engine is running and in park?
8th May 2014 3:23pm |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
Just checking that you have the parking brake on as well as mine only works when in Park and with the parking brake applied unless I put in to test mode. It is designed only to work when parked as a safety feature although there are ways to bypass this apparently. There is a difference between knowing your sh!t and knowing you're sh!t
8th May 2014 3:41pm |
No it is only working without the key in the ignition, as soon as in put the key in the screen cuts out with "for your safety blah blah" the hand break is on |
8th May 2014 4:21pm |
Im not trying to get it working whilst in gear, just as it should thanks. |
8th May 2014 4:23pm |
Ebay |
8th May 2014 4:37pm |
Do you get the red light on the dash when the handbrake is on? My TV would not work for a while as the contact was not sensing the handbrake being on.
8th May 2014 4:45pm |
Ive just had a look and there is no red light on the dash when the handbrake is on! I have never noticed this before. Is this an easy fix? sound works and just pulled it outside my unit and got a load more channels. |
8th May 2014 4:56pm |
The sensor on mine that was not registering was at the base of the parking brake (I was able to see by removing the cupholder/ashtray from the centre unit) From memory it is a white plastic block that moves with the handbrake, mine was being block by a misplaced wire stopping it moving freely.
8th May 2014 5:02pm |
