Home > Off Topic - Other Cars > FFS RANT disco roof rails. |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
I just HATE the quick, simple job that ends up taking half the day. I feel your pain. |
10th May 2014 8:52pm |
Tell me about it! There is nothing that can't be fixed with a hammer😜😜
10th May 2014 9:17pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1898 |
I feel your pain there, seems the '5 minute' job always take all flippin day to do.
10th May 2014 9:32pm |
IT issues at work come to mind. 30 minutes to print out a one page spreadsheet... |
10th May 2014 10:56pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16180 |
My D4 extended roof rails were delivered yesterday morning... Am i in for a treat then |
10th May 2014 11:03pm |
The little plastic clips are the pain, they wont pull out, it is possible to screw then out gently but more often than not they snap off, they seem to be an "improvement" over the d3 where the gutter trims are pictured as clipping in, god knows why, all bar 2 of mine snapped off. Obviously be careful drilling them out, i managed not to drill through the roof but it would be all too easy!
10th May 2014 11:15pm |
Mine is an HSE so already has the short rails as standard so I'm hoping this will make life much easier??? |
10th May 2014 11:18pm |
Possibly, they should just screw off then you will only have to take the clips out of the holes on the lower section of the roof, and then get the plastic out and bolt the front fixing on the extended rails into the exposed captive nut the rails bolt over the gutter trim. Piece of pee for a man with enough tools!
10th May 2014 11:28pm |
10th May 2014 11:32pm |
Right, tap extractor worked a treat and the offending broken tap is out, roof rails securely attached with a replacement stainless m6 button head screw,
12th May 2014 7:04pm |
Fitted mine today sir... `mine has plastic stoppers in the unused front holes that just flick out with your finger nail... Sorry pal, i know that doesn't help But made mine a doodle to fit .....
12th May 2014 8:14pm |
Grrrrrrr, bleeding improvements. Anyhow, all done now so happy camper.
12th May 2014 9:23pm |
