Home > Technical (L322) > Aircon only out of passenger side??? |
Swithins Member Since: 22 Oct 2013 Location: West Malling Posts: 149 |
Morning All,
4th Jun 2014 9:28am |
Cheers Cam Gona try a re-gas first and see how that pans out. Current:
4th Jun 2014 10:02am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16180 |
4th Jun 2014 10:33am |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
Low gas DOES give this quirky little annomoly .... I had same last year and explored all the possibilities off FUBARD blend motors etc.
4th Jun 2014 5:35pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
^ I can con cure as I have a very similar car and very similar symptoms i,e, only cold on passenger side as gas gets lower and audible whine at idle . Takes a very long time for the gas to go down so have never traced the leak just make sure you have the rear heat/air turned on when you get a re-gas 2008 MY Supercharged
5th Jun 2014 2:27am |
Getting a re gas now so fingers crossed Current:
5th Jun 2014 1:47pm |
Re gassed and working perfectly Current:
5th Jun 2014 11:24pm |
Excellent news |
5th Jun 2014 11:35pm |
My 4.2 SC had the same when the AC went low. It takes about one year for it to deplete so also tiny leak and also performance reducing (to one side eventually). MY 2010 5.0 SC Galway green and sand interior!!
5th Jun 2014 11:40pm |
So there we are
6th Jun 2014 1:52am |
I have to admit to being guilty of not using the aircon on a regular basis, which I am told you must do to keep it in good condition, but when its freezing outside its very difficult to justify hitting that little button, unfortunately I don't live in Australia or Malaysia Current:
6th Jun 2014 9:35am |
Another way to look at it is A, it keeps your windows de-misted in the winter & B, it stops your ECU's condensating through the winter if you use the AC...
6th Jun 2014 9:43am |
