Home > In Car Electronics (L322) > TV antenna booster - worth a go??
Gaity
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Evening all
I have a 2007 RR Vogue SE and wondered if a booster antenna would get a better TV reception?
http://www.ebay.co.uk/itm/ANT29db-5V-Feed-...2c647d71cc
Any advice welcome Thumbs Up
Post #263486 5th Jun 2014 9:00pm
I have two of those on my car and my tv never drops out. Thumbs Up
I live in a fairly rural area though where reception is excellent, can see the transmitter most of the time.
I've travelled over 100miles with the tv on and have been told by my passenger it hasn't dropped out.
I'd have to check but I think mine have different connector plugs, you'd need the correct connectors for your car or possibly adapters.
It may be worth pointing out that you can buy these aerials significantly cheaper on Ebay.
Post #263496 5th Jun 2014 10:12pm
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Love to hear some feedback if you (or any others try this) tv reception is v poor where I live so the tv on mine is barely ever used. (2011.5MY in case that has any specific plug requirements) 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #263527 6th Jun 2014 6:49am
Gaity
I may as well just buy one for the money, any advice on fitting it to the TV tuner is welcome Thumbs Up
Post #263529 6th Jun 2014 7:26am
Elduke
Scotland 2004 Range Rover Vogue 4.4 V8 Zambezi Silver
I've tried one of these and it made no difference so ended up going for a more expensive mag mount version which is marginally better when used outside of the car.
I believe its all down to the reception in your area Rolling Eyes
Post #263612 6th Jun 2014 11:20am
Prop
Gaity, keep us informed of your results please.
Post #263664 6th Jun 2014 1:38pm
tanertimur
England 2005 Range Rover Vogue Td6 Java Black
I bought two of these and fitted it to my after market freeview player and works a treat having them on the window on eighter side at the rear.
Mine are different connector, but that obviously depends on your unit you are connecting to. Range rover td6 54 reg touch screen
Post #265734 16th Jun 2014 4:34pm
