Home > In Car Electronics (L322) > Bluetooth problems |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 |
in my MY2006 SC I get in and connect my phone to the Bluetooth. It doesn't download or show the phone book so when someone calls unless I can see my phone screen I just get a phone number and do not know who is calling. If I turn the car off and use it again a few minutes later I have to connect and pair again to the car and I have to do this every time.
19th Jun 2014 8:49am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
19th Jun 2014 9:36am |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
I forgot about this.
19th Jun 2014 10:05am |
That is the most annoying thing to be honest, any idea on cost for the upgrade as there aren't any prices on the website.
19th Jun 2014 10:11am |
Reading the website says that the constant pairing stops and the phone book is downloaded and to be fair for £65 it seems a very good deal indeed.
19th Jun 2014 1:55pm |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
I have a Bluetooth upgrade from Wiggs/bluetoothexchange - mine stays paired and uploads the phone book
19th Jun 2014 3:18pm |
Is it worse since the upgrade or the same? Alex
19th Jun 2014 3:32pm |
There is a better upgrade to the standard firmware flash upgrade that can be done easily enough as I have done with the later units. Requires two cables being cut into and job done.
19th Jun 2014 3:59pm |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
Mine was fine after the update and clear to hear both ways. The problem came some weeks after the upgrade so I don't believe the two are connected. There is a difference between knowing your sh!t and knowing you're sh!t
19th Jun 2014 4:00pm |
Alex, sound quality was the same before and after the upgrade - the RR is just not as good as the Merc
19th Jun 2014 4:09pm |
I'll have to find the link later but for your fault have you tried replacing the mic for the later one?
19th Jun 2014 4:16pm |
I got a new microphone from Dan but sounds just the same. I even uninstalled my Pure DAB in case it was interference and unplugged the phone charger and radar etc... but no difference. Seemed to go bad overnight. There is a difference between knowing your sh!t and knowing you're sh!t
19th Jun 2014 5:35pm |
Have you checked for water ingress in the rear compartment? Could be rusty pins on the connector/module... 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car! |
19th Jun 2014 7:19pm |
Got my unit today after not ordering it as I was busy so will be fitting tonight or tomorrow night and trying it out. Went on holiday in the car in August and it was a pain having to pair the phone every time I got in and out of the car.
16th Sep 2014 3:22pm |
