Home > Maintenance & Mods (L322) > Coolant - how much and what type? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34949 |
this might help,
21st Sep 2013 10:10pm |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
Regardless of it being summer anti freeze also contains corrosion inhibators. Not a good idea to run the system with just water for any length of time. |
22nd Sep 2013 1:17pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6400 |
Suggest you drain it both from the rad and engine block, give a good flush then refill with 50/50. .
22nd Sep 2013 1:48pm |
Is it safe to top up with the same spec and type coolant albeit made by a different manufacturer?
19th Jun 2014 2:06pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16185 |
I would seriously think about using another mechanic my friend... Thats not good practice at all... At best he should have booked you in to replace your coolant rather than leave you to potentially run around for months without... |
19th Jun 2014 9:39pm |
Parts Dept at RR main dealer said as long as the coolant is pink, organic and same spec it can be mixed with that of a different manufacturer to the one they use. Better safe than sorry! |
20th Jun 2014 3:08pm |
As the RR dealership was too far to justify going to for pink coolant, visited the local Jaguar dealership this afternoon and was assured this pink coolant is suitable for the 4.2 and can be safely added to top up the existing RR dealer supplied coolant.
20th Jun 2014 6:13pm |
Come on chaps.. Tumbleweed on this one.. do we think I'm safe to top up the existing coolant that's in the system with the Jaguar coolant? ... Or not
20th Jun 2014 10:19pm |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 |
I would do it without worrying. so long as its pink I would mix with other pink stuff. |
20th Jun 2014 10:39pm |
You'll do for me Prop, thank you.
21st Jun 2014 7:06am |
Main dealer has today confirmed that the below Jaguar pink antifreeze coolant is suitable for the L322 4.2 SC and is made of the same ingredients as the Oat 5 that they use.
26th Jun 2014 3:10pm |
Told you it was ok,,,, |
26th Jun 2014 3:15pm |
And I believed you Prop |
26th Jun 2014 4:52pm |
Phew thank god it was the right stuff. |
26th Jun 2014 4:58pm |
