Home > Technical (L322) > L322 2002 Vogue O/S Wing mirror focus |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
I agree. Focus is OK with me, but there is a big blind spot. If I ever plan to move out a lane, I always have to look over my shoulder. Wasn't a problem in my P38? Think the mirrors had more convex in them. .
27th Jun 2014 3:55pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7927 |
Totally agree, both of mine were totally useless when I got it, you could lose a 7 1/2 ton lorry in the blind spot...
28th Jun 2014 12:13am |
28th Jun 2014 12:51am |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 |
@Joe 90 - just look at your glass. If they are auto-dim, it will have a goldish tint, if the tint is greeny blue then they are just heated (also for auto-dim door mirrors you must have the (optional) auto-dim interior mirror.
28th Jun 2014 7:01pm |
I have the auto dim interior rear view mirror (tested with torch and everything!), but woulnd't say my external mirrors have a goldish tint. Out with the torch again to see what happens .
29th Jun 2014 1:13am |
If you have auto-dim, then when you dim the interior one with the torch, the exterior ones should dim too (they use the same sensor, which is why you have to have the interior dim option before you could specify auto dim exteriors).
29th Jun 2014 4:34am |
Well I have bought one of the eBay ones linked to by Haylands ( ) to try, will let you know how it goes .
29th Jun 2014 4:58pm |
Mike.Boro Member Since: 09 Dec 2013 Location: Middlesbrough Posts: 44 |
I fit a pair of these, because of the same problem. Got them from the same company, pain to fit. They don't line up that well with the original mounting plate, but for the price, they are not going to be perfect. Had to get the Dremel out and remove a bit of the plastic from the back of them (after breaking one ), and put a blob of silicone on the back to keep them in place.
30th Jun 2014 9:29pm |
My Drivers Side arrived today so set about fitting it this evening.
1st Jul 2014 9:23pm |
Much better, blind spot gone, rear view mirror and wing mirror working together, vehicle in next lane out either in mirror and/or in physical view, even better for two lanes out!
2nd Jul 2014 10:09am |
Glad you like it Jo, it is quite a difference... do the other side and you won't lose a thing in a blindspot...
2nd Jul 2014 9:45pm |
Fitted passenger side today, I can now see round corners on both sides .
28th Sep 2014 6:05pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 785 |
Nearly wiped some one out on the M6 on Saturday because of the blind spot. They were completely invisible. Is there any fix that allows you to keep your auto dimming feature ? |
29th Sep 2014 7:02pm |
Don't think so, unless you can find a replacement/after market that is convex and has heated and auto dim .
29th Sep 2014 7:15pm |
