Home > In Car Electronics (L322) > Can someone help: Battery Voltage |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6355 |
If I have the car doors open for a while or tinker with the stereo (engine off) it only takes a few minutes for the warning on the dash saying "Low Battery Please start engine"
18th Jul 2014 1:13pm |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 |
Just been out and tried mine which hasn't run since mid day yesterday. At rest it is showing battery volts at 11.9 / 12 volts and when I start the engine it charges at 14.5 volts. From past experience when using the radio with the engine off it doesn't take very long to get the low voltage message, I believe it is a Range Rover " feature " . Agueroooooooooo. 93-20
18th Jul 2014 2:35pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Do you love your car so much you sit inside it and listen to the radio? |
18th Jul 2014 2:39pm |
If I happen to be waiting for SWMBO coming out of the hairdresser or suchlike, then yes. Agueroooooooooo. 93-20
18th Jul 2014 4:28pm |
Thanks for the replies.
19th Jul 2014 8:38am |
In my experience with large industrial diesels with 24 v systems (2x12v) , then each battery would have to be at least 12.5v to give a reasonable chance of turning an engine sufficiently to start it depending of course whether it was a cold engine or already been run etc. I think the screen voltage shown on the Range Rover is somewhat misleading as when entering the 753 mode on the screen then other things are already running in the background thus bringing the recorded voltage down. I suspect if you isolated the battery from all systems and then take a reading across the terminals then with a healthy battery a reading of 12.5vdc or even higher would be obtained, probably nearer to 13vdc. Agueroooooooooo. 93-20
19th Jul 2014 9:05am |
ppcsl Member Since: 12 Sep 2012 Location: Ellon, Aberdeenshire Posts: 107 |
Hi rr 2010 is a bit new for a dodgy battery issue but we are talking about a range rover after all. Lol it is four years since new. The electronic load on the battery may have been so excessive that the "quality parts Land Rover use on such expensive cars that mostly footballers and CEO buy they don't give a ****) I would go and have the battery tested at a good garage you know and trust NOT a main dealer. A good replacement will cost you £120-160. You could try first disconnecting the battery for a while, can't remember the sequence for such a new car so search the forums.
23rd Jul 2014 11:44pm |
