Home > Maintenance & Mods (L322) > The drive you mad water leak. |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 416 |
If it's a BMW M62 4.4 (looks like it) the alternator is on the other side and not above that point so highly unlikely to be that.
24th Jul 2014 7:40pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 785 |
Ummmm, your right ! Now the mystery deepens even more. |
24th Jul 2014 11:43pm |
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 |
My TD6 did exactly the same after we'd done the water pump and rad.
25th Jul 2014 11:33am |
Think I've traced it to the water hose that comes from the rad to the thermostat housing ( V they have an O ring in which should be replaced when ever you've had the hose off but when I tried to buy one was told you had to buy the whole hose ? |
25th Jul 2014 11:56am |
You can't get the O-rings separately but just hook them out and buy the equivalent size. Obviously if the hose is past it's best then just get a new hose, I went for new hoses when I changed my rad. |
26th Jul 2014 2:36pm |
