Home > Technical (L322) > Suspension vibration only in right hand corners |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2543 |
Anybody....... |
28th Jul 2014 7:34am |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 |
Hmmm - personally I'd give it a good coat of looking at before driving it any further. In particular check your steering arm ball joint and wish bone ball joint / bushes.
28th Jul 2014 8:38am |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
100% lower suspension arm... Common problem. It only did it to me on long sweeping corners at speed. It can give quite a shake/knock.
28th Jul 2014 9:42am |
Cheers guys, was worried it may be something I hadn't heard of |
28th Jul 2014 10:45am |
trainmanone Member Since: 26 Jul 2012 Location: stockport Posts: 201 |
did you get this sorted I have similar on left hand bends at 50-60 mph
2nd Aug 2014 8:02am |
It was the lower suspension arms on mine, had both changed and all sorted, |
2nd Aug 2014 10:03am |
thanks will do n/s one just had o/s done have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
2nd Aug 2014 11:23am |
had them done still the same but now on the straight have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
4th Aug 2014 7:13pm |
I would suggest that if it is now doing it on the straight and it wasn't before the work was carried out, then it's not been done properly... Has it been tightened up correctly? Is it tight? Previously..
4th Aug 2014 9:24pm |
Check with the Mecanic if he tightened the main through bolt on the ground or with the car in the air.
4th Aug 2014 9:32pm |
