Home > Maintenance & Mods (L322) > Air con condenser removal
Page 1 of 4 1234>
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Please note you must have the air con system completely empty before you start this how too take your vehicle to be de-gassed prior to opening up the aircon system as venting out to the atmosphere is illegal
I thought as summer is nearly upon us I would share this how too.
I wanted to regas the FF as the air con was not as cold as it should be last week, but the garage couldn't do it
as the gas was leaking out near the bottom of the condenser, big time Big Cry
So new condenser bought from Autoairconparts for a reasonable price, £72 plus vat.
An easy job to do if your brave enough with your spanners and shouldn't take more than 1 hour 30/45 min....if you don't have a dog that likes your tools though Whistle
Pic 1 and 2
Remove all the small m6 bolts that hold the grill and bonnet catches.
Remove the 4 ( 2 each side of slam panel) m8 bolts.
Remove all 3 smaller screws that hold the plastic covering that's under the slam panel.
Pic 3 and 4
Bonnet catches undone and plastic panel is only snap fixed in place, remove this will expose the condenser.
Pic 5 and 6
Air condenser is locked in place by these, just un screw and comes apart, there is a rubber thread part to the bolt.
Pic 7
I took the air filter housing off and engine cover ( needed to get to the jubilee clip) as it made undoing the bolts for the pipe work that fit in the condenser easier.( just be mindful that a clip can fall down the engine bay ...... Whistle )
Pic 8
Air con bolts, these where alan screw bolts and are tight, there is also a self tap screw under the lower pipe ( red arrow)
Pic 9
Just slide the condenser out as its between the radiator and oil cooler
Pic 10
As you can see its a tight fit, so care is needed when fitting a new one
Pic 11
New condenser fitted, but I had to trim a couple of mill off the plastic trim in front of the condenser as it was touching the fins while sliding down into place.
Pic 12
The old condenser pipes that go into the core had corroded, the bottom one been the worsted pipe.
Pic 13
All done and just need to regas and then be cool in the cabin!
Hope it all makes cense Thumbs Up If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #263790 7th Jun 2014 9:56am
5 minutes after posting and its in the wiki, boy i'm on the ball today Mr. Green
excellent 'how to' Thumbs Up ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #263794 7th Jun 2014 10:02am
Welshdragon
Thanks Stan Bow down Thumbs Up If it dont work.......burn it!
Post #263796 7th Jun 2014 10:07am
Prop
Nice job Welshdragon, its sure to help others.
Post #263804 7th Jun 2014 10:37am
My job this week, will let you know how it goes Smile .
Post #273438 29th Jul 2014 3:40pm
if a numpty like me can do it tim then i think you'll have no problems.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #273440 29th Jul 2014 3:42pm
Welshdragon
Simples to do TIM, won't take you long, the hardest part was finding the tools my dog nicked! Rolling with laughter If it dont work.......burn it!
Post #273459 29th Jul 2014 6:17pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Just a point to note that it is illegal to release the gas from the aircon into the open atmosphere. So unless you know that the system is completely empty you should take your vehicle to be de-gassed prior to opening up the aircon system 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #273463 29th Jul 2014 6:32pm
^ just beat me to it. There was obviously gas in the system as it was still working.
At the start of this how to it might be an idea to state that the gas should be removed legally before work starts. Previously..
Post #273464 29th Jul 2014 6:36pm
Welshdragon
Re: Air con condenser removal
NO garage will fill the air con system up when a leak has been detected, no matter how big or small it is, well a good garage wont.
I have eddited as some on here might not know about de-gassing. If it dont work.......burn it!
Post #273478 29th Jul 2014 7:56pm
I put the ffrr into an air con specialist to find out what was wrong. I also checked with them that it was empty and safe for me to replace my condenser.
Do I need a new drier as well? .
Post #273531 29th Jul 2014 10:18pm
Welshdragon
I didn't do mine, just the condenser as those brazed pipes where the problem, the lower one been the worst. If it dont work.......burn it!
Post #273535 29th Jul 2014 10:21pm
@tim, is the dryer not part of the condenser? [right side as you look from the front] ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #273554 30th Jul 2014 7:21am
That is what I thought ?? Must have a look at RAVE again .
Post #273569 30th Jul 2014 9:44am
steve9bug
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
cool might give mine a go soon
Post #273666 30th Jul 2014 9:00pm
Page 1 of 4 1234>
