Home > Off Topic - Other Cars > Defender ABS shutle valve failure |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 914 |
Hi Geoff, the shuttle is part of the modulator unit (next to the brake pedal box on a defender, just inside the wing). Its a pain to get to on defenders, disco2s have the same set up but much easier access. To get a better view you have to remove the wing side air intake
5th Aug 2014 11:47pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1699 |
I believe the pump has to be removed, to access the bottom of the ABS pump, to fit the new shuttle valve.
6th Aug 2014 7:00am |
Have done them before in situ, but its not a nice job
6th Aug 2014 9:45am |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 416 |
Bare in mind that a new shuttle valve switch pack is not necessarily the fix. The pins that the pack fits into inside the modulator can be the problem as the solder joints crack over time. Also the earths need checking for corrosion and wiring for broken cores which are obviously simpler and cheaper fixes.
6th Sep 2014 10:36am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3199 |
As stated above, the SVS is located on the underside of the brake modulator. I did this mod on my Disco TD5 (I am having a problem linking to the original BVI LR Club site) and haven't had a repeat of the problem. Do a Google search on the 3 amigos and you will get a few links to the mod.
6th Sep 2014 12:14pm |
