Home > General (L405) > Wear on 22" Continentals
CSK
France 2013 Range Rover Autobiography 5.0 SC V8 Causeway Grey
I'm probably taking the plunge on a stock SC L405 AB next week. Car has the 22" Contis. I used to have those on my L322 but changed brand because of the well known premature wear on the outer edges.
What about the 22's on the L405? Do they have the same problem?
Thinking about putting winter tyres of the same size, I see JLR recommends the Conti winter tyre in 22". Anyone tried those yet? Are they any good?
Post #277466 26th Aug 2014 12:00am
I run them (405 tyres) on both my FF & my Disco and have done heapes of miles and they are wearing evenly and 100% without issue Thumbs Up
Post #277467 26th Aug 2014 12:11am
CSK
Thanks for your input Craig. Strange that the uneven tyre wear issue is only with the 20 inch Conti's.
Glad they're OK in 22 as I think that is the only tyre JLR recommends in that size for the L405.
Are you running Conti 22's as winter tyres as well or are you running the same ones in winter as they are rated M+S all-weather?
Post #277472 26th Aug 2014 6:15am
Call me a tart sir but i don't run the car in the winter as A, its our "shop window" so needs to be gleaming as much as possible! (only takes 200yrds around here in the winter and they look filthy) & B, we have older less valuable or "more suitable" cars here to use in wintery conditions... i.e. my bobtail D2 on cooper LTZ's Thumbs Up
The fact that 22" conti's work & and as reported here often 20" don't is not too surprising to me as just like the Conti's, TOYO Proxes don't work/wear well as a 20" but do as a 22"! Pirelli Scorpions work/wear well as a 20" but are imho the worst wearing 22" premium tyre available for the 322...
Im not sure if the above is related to difference in compounds between sizes? But I'm sure a more informed someone will be along at some point to tell you sir Thumbs Up
Post #277473 26th Aug 2014 7:55am
CSK
Thanks, very informative! Thumbs Up
Post #277489 26th Aug 2014 9:46am
johnf
2013 Range Rover Autobiography 5.0 SC V8 Bonatti Grey
I have them and am on 28,000 miles now. Will need changing before the winter but still have a good 3mm tread.
Post #277491 26th Aug 2014 9:54am
I think Stan also said the tread pattern had changed on the continentals?
Post #277495 26th Aug 2014 10:03am
MachineHead
Scotland 2009 Range Rover Westminster TDV8 Mariana Black
I can only speak for myself but i find in general continentals wear too fast, they never seem to last no matter what car I try them on. 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts
Post #277518 26th Aug 2014 12:06pm
CSK
My query is specifically aimed at 22's. Did you run your RR on 22's to be able to comment on this particular tire size? Craig said they wear differently depending on the size. If you did I'd be grateful of your personal experience.
Post #277553 26th Aug 2014 3:38pm
johnf
Mine are 22"
Post #277557 26th Aug 2014 4:05pm
CSK
Thanks for your input John, but my remark was aimed at MachineHead as my question was specifically for 22's. I have personal experience of 20 Conti's already.
Post #277565 26th Aug 2014 5:30pm
MachineHead
Sorry no I ran my Disco on 18's never run 22's I'm afraid. My FF is on20's but they are Pirelli's due to Conti's in general wearing quite quickly in my experience 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts
Post #277580 26th Aug 2014 7:07pm
CSK
No problem. Yes I currently run Pirelli's too because of uneven tyre wear with my Conti's 20". Will hopefully be able to give you some feedback myself once I have driven enough miles with my L405 (Should close the deal next week, fingers crossed).
Post #277581 26th Aug 2014 7:26pm
