Home > In Car Electronics (L322) > Which C Tek battery charger? |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 539 |
Message from seller
5th Sep 2014 11:33pm |
mmiata Member Since: 12 Jul 2013 Location: Budapest Posts: 104 |
I don`t know if anyone is worried about AGM battery recondition (which according to vendor differs from normal battery recond, and from AGM charging as well).
6th Sep 2014 7:16am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7635 |
J evro, your man is right. If all you ever want to do is maintain your battery, the 3.8 will be fine. It's a 3.8 on ctek webpage. If he has a 3.6 is it an older model ? Or a typo....
6th Sep 2014 8:06am |
Thanks chaps ,
6th Sep 2014 10:35am |
I think it's some later gel type arrangement. Don't know much after that myself.
6th Sep 2014 1:57pm |
Yes sorry being lazy , but I'd rather hear from someone on here as they sometimes add more info/ experiences I find
6th Sep 2014 2:05pm |
Nothing like what I thought then. Never really needed to know. Thanks for the info.
6th Sep 2014 2:12pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
What are the problems (if any) of using a higher amperage batterie conditioner/charger ? 2008 MY Supercharged
7th Sep 2014 4:11am |
No problem, it will charge it faster. If you compare a 5 amp to a 7, the 7 should be 40 % faster on paper. Though won't get that much increase in the real world. 2011 Range Rover Vogue SE 4.4 TDV8
7th Sep 2014 6:44am |
Grrrrr
7th Sep 2014 11:20am |
