Home > Technical (L322) > Question to those that replaced ARB due to clunk. |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 |
I had exactly the same on my L322 5L SC AB, never heard the clonk on normal roads but when I took dirt tracks (so daily in my case as I take the dirt track to access my home), I always had this clonk in the front suspension.
15th Oct 2014 2:39pm |
MachineHead Member Since: 20 Apr 2014 Location: The hoose Posts: 310 |
Yeah testing a clunk that happens off road on a road is a bit daft. At least the garage I use go the extra mile
15th Oct 2014 3:02pm |
Machinehead if you've read my posts you'll probably have worked out that I'm not bad at keeping things shiny and clean but my mechanical enthusiasm outweighs my actual ability!
15th Oct 2014 3:13pm |
I hear what you're coming from, my garage are an amazingly honest bunch, they phoned me to say they didn't want to replace the ARB if unsure because although one bush has moved they cannot be 100% certain it is the culprit. They are certain it's not the drop links and that there is no play in them, there is however some play in ARB which makes it the likely suspect. The ball joints and suspension are all fine.
15th Oct 2014 3:38pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1698 |
Does it happen when you "dab" the brake pedal sharply? |
15th Oct 2014 3:43pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
The ARB clunk usually sounds like it is coming from the rear.....?
15th Oct 2014 5:26pm |
It doesn't occur when I brake, nor when driving at road speed on the bumpy poor surface roads up here.
15th Oct 2014 6:31pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7929 |
My 2002 did the same, I changed the drop links as they were old anyway, my ARB bushes looked OK but I bought two new ones anyway in a bid to cure it, I first disconnected the drop links and drove it about and the noise was gone so it can only have been the ARB bushes. Anyway took the saddle clamps off them expecting them to fall out and they are still totally fixed to the ARB and had no wear or perishing on them.... I decided to just put the clamps back and have a rethink and low and behold the clunk has gone, that was several weeks ago now and it has all been quiet!!??!?!??!
15th Oct 2014 7:47pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I'd go for the drop links, they are a common source of annoying knocks from the front on a Landcruiser, and a really easy fix. I can't see it being the anti roll bar its self, as there is nothing to go wrong. It is just a bar with 2 holes in it, unless one of the drop links has worked its self loose and elongated the hole. The only other cause would be a failed bush, and that normally is easy to spot, especially if theres a leak of oil / derv. For some reason, beyond me, they only make the bushes out of cheap rubber thats eaten by every substance known to man!
15th Oct 2014 10:22pm |
Thinking of having clamp removed and packing the ARB bush that has some movement then re clamping it to see if in the short term it stops it, thereafter replace ARB if it does. Can't even change the bush as the whole ARB is sold as a unit now.
15th Oct 2014 11:00pm |
You could remove them and go for a drive just to see if the knock has gone, just don't go throwing it into corners! Yesterday I couldn't spell Engineer... Today I are one!
15th Oct 2014 11:41pm |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 |
[quote="MachineHead"
18th Oct 2014 3:35am |
There was no obvious play on either of our drop links but they were the source of the clunk |
18th Oct 2014 5:35am |
if I get a moment i'll whip em off (drop links before anyone barf ) knowing my luck they will be a pig to remove on mine. 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts |
18th Oct 2014 2:57pm |
