Home > General > Water in the Boot |
Macdaddy Member Since: 15 Oct 2009 Location: Preston, Lancashire Posts: 466 |
A common place for leaking on that side.
20th Sep 2010 12:36pm |
hongkongphooey Member Since: 27 Aug 2010 Location: Douglas. Posts: 227 |
A good idea. I'll get some thin fuse wire and check the drain holes and maybe some silicone rubber lube (oo er), see if that helps.
20th Sep 2010 12:59pm |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 |
hongkongphooey - now you have had the dreaded water in the boot problem, Can I suggest a couple of things to do?...
20th Sep 2010 1:29pm |
Hi Delamo,
20th Sep 2010 5:59pm |
Found it
21st Sep 2010 6:15pm |
