Home > Technical (L322) > Door Lights |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
Its all in the latch sir |
20th Oct 2014 9:11pm |
zoso Member Since: 20 Aug 2014 Location: Ayrshire Posts: 79 |
Thanks Craig - do you know the part number of the latch so I have an idea what I'm looking for ? The remote operates all the doors except the drivers so am I correct in thinking that's all to do with the same thing ?
20th Oct 2014 9:21pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
Has it worked since you've had it, if not it could have had the plug pulled out by someone in the door...
20th Oct 2014 9:29pm |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
I had a similar problem.
I've had the door card off and the plugs are all okay. I also sprayed the whole lot with WD40 while I was at it but it made no difference. The one touch window works okay for the drivers side but will not operate any other windows !! The switchpack also operates the drives mirror but not the passenger side - confusing 2017 4.4 TDV8 Autobiography
20th Oct 2014 9:34pm |
Send Dan a PM with your VIN sir |
21st Oct 2014 12:09am |
Look behind the bonnet pull panel, maybe a loose connection block there, with the windows not working properly as well you would think it was more than the latch??? Mind you its an FF so anything is possible...!! Pete
21st Oct 2014 9:51am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34917 |
there's six'ish plugs you need to make sure that are properly inserted in their relevant sockets...sounds like one might be loose. ... - .- -.
21st Oct 2014 10:11am |
Thanks - I'll take the bonnet pull panel off at the weekend and make sure all six connectors are connected securely. 2017 4.4 TDV8 Autobiography
21st Oct 2014 12:32pm |
sorry , i meant behind the door card.. ... - .- -.
21st Oct 2014 12:48pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
+1 stan I had the same a few weeks back when my door cable snapped. Make sure all connectors are fully inserted even if they look like they are already, disconnect and reconnect took me a couple of off on goes before the electrics worked ok again. |
22nd Oct 2014 6:28am |
Had the same issue with the 2006, door card had been off for new door handles and the driver one the connector wasn't on properly although it looked like it was. Installed it properly and everything started working again MY 2010 5.0 SC Galway green and sand interior!!
22nd Oct 2014 6:54am |
espaceboy Member Since: 02 Aug 2014 Location: Fae Fife Posts: 86 |
don't know if this will help
22nd Oct 2014 9:04pm |
That sounds feasable Ricky. I'll take the door card off on the next dry day.......next spring probably !!! 2017 4.4 TDV8 Autobiography
23rd Oct 2014 12:18pm |
