Home > Maintenance & Mods (L322) > If I drop 20mm with IID Tool do I need to do tracking |
Robgosty Member Since: 20 Dec 2013 Location: Manchester Posts: 232 |
Hi all, as above had a 4 wheel alignment done a few months ago but now got IID Tool, could do with dropping 20mm all round (easier access for arthritic wife) but don't fancy forking out for alignment again |
22nd Oct 2014 8:26pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1698 |
Tracking should be advised when any suspension heights are altered, in either direction |
22nd Oct 2014 8:55pm |
Still no wiser |
24th Oct 2014 10:28pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
1. Don't do it
24th Oct 2014 10:36pm |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
I believe, from reading a subject a few weeks ago, that 2007-onwards models don't have a 'motorway mode'.
25th Oct 2014 8:12am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1274 |
In contrast to what Joe90 says
25th Oct 2014 8:23am |
25th Oct 2014 9:10am |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2522 |
First question should surely be why have a 4x4 if you want something low to the ground?
25th Oct 2014 12:04pm |
If it is just getting in and out, why not use access height for that. I'm pretty sure you can lower access height a bit even if you wanted to without affecting the ride height at all. MY 2010 5.0 SC Galway green and sand interior!!
25th Oct 2014 1:05pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Post about 2005 the BCM wont accept different hight changes for different suspension settings so 20mm lower for standard height will mean 20mm lower for everything . 2008 MY Supercharged
25th Oct 2014 2:06pm |
Did you even read my original post ? @ ebajema If it is just getting in and out, why not use access height for that. I'm pretty sure you can lower access height a bit even if you wanted to without affecting the ride height at all. Not on a 2007 @ Mikey appreciate the feedback but according to dingg1 he has done it with no problems so still no wiser @ joe90 my book of words (page 190) says high "speed height" raises suspension 20mm if driven at over 100mph for over 5 seconds So appreciate all the replies but now have a load of conflicting information, so best bet is to buy wife a portable step and leave R/Rover alone |
25th Oct 2014 7:13pm |
Weigh up the cost of an alignment, versus the cost of 4 tyres
25th Oct 2014 7:19pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34940 |
if you do drop it then just keep an eye on the tyre wear, if it starts going on the edges then put the height back to normal.. ... - .- -.
25th Oct 2014 7:33pm |
At that point though, it's too late.
25th Oct 2014 7:45pm |
