Home > Maintenance & Mods (L322) > A-Pillar Interior Leak (not sunroof drains) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34924 |
windscreen or maybe the door rubbers..use tape and check with water.. ... - .- -.
5th Nov 2014 9:47am |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
Poorly fitted replacement windscreen - that's what happened with mine
5th Nov 2014 10:53am |
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 |
I had the same thing on mine just a couple of days ago and am drying it out as we speak, i took the A pillar trim off and poured some water down the screen and it was coming in quite fast, dryed it all off and then sealed from top to bottom of the screen, is nearly bone dry inside now and touch wood seems to have solved the problem, mine had a new screen fitted about a year ago so if yours has had the same at some point in its life then will most likely be the same problem. |
5th Nov 2014 12:19pm |
