Home > My Range Rover > Project Fatty off roader....PICTURES NOW BACK |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
Thanks for the info Pete, what did you use to coat the final fibre glass shiny black? Howard
28th Oct 2014 10:40pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
This is gloss black paint, well prepared beforehand to be as smooth as possible
28th Oct 2014 11:23pm |
Thanks - it looked so smooth I thought it was like a silicon finish - well done Howard
29th Oct 2014 9:10am |
Well it's only taken three months but I have finally found a MemoryMap.apk file that actually works with the Android head unit, for some reason when I tried to download it from the google play store it kept saying I didn't have a compatible device, even though I had downloaded lots of other apps OK... it just didn't seem to like MemoryMap, looked around for the file to load it from the SD card and found a fare few but they all crashed or didn't load.... had a look last night and found a new one and..... it works.... loaded an old overlay and can see it, it knows where I am and moves when I do....
18th Nov 2014 9:42pm |
It is really useful to know this thermostat solution exists - well done for finding and highlighting it.
18th Nov 2014 10:08pm |
They put a 110deg stat to reduce emissions at part throttle openings, it will have minimal, if at all, effect on the way they measure them for an MOT....
18th Nov 2014 10:37pm |
My gut feeling is that 108c is fine when engine is new but would rather it is cooler 90000miles later for reasons you mentioned.
18th Nov 2014 11:35pm |
It's certainly not as hot as it was.... thank god, it was ridiculously hot before, thought it was going to melt the vents...
19th Nov 2014 6:30pm |
Dean Member Since: 23 Mar 2014 Location: Glasgow Posts: 51 |
Hiya,
24th Nov 2014 9:24pm |
Just using a mag mount at the moment, don't use it much.... Pete
25th Nov 2014 1:27am |
Thanks, think I'll be going with that too as I can't find any neat and tidy brackets / solutions.
26th Nov 2014 12:53am |
Couple more jobs done recently, one of the rear lower hub rose joints started squeaking like mad, it was starting to scare children and old ladies....
3rd Dec 2014 10:55pm |
Kaj Member Since: 28 Oct 2014 Location: Jeddah Posts: 4 |
Excellent work Pete
25th Dec 2014 5:30pm |
chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130 |
Would you make one of those fibre glass boxes for the snorkel for us if we asked nicely? =o
25th Dec 2014 6:56pm |
