Home > Wheels & Tyres > New Hankooks Fitted
RiccartonRR
New Hankooks Fitted
Just had 4 new tyres fitted today after discovering the Pirellis were absolutely goosed on the inside. Loads of tread - read, like new - but the tread had come away all the way around and on one front one wire strands were poking out through the rubber despite 5mm of tread Shocked I guess 35 profile tyres aren't fond of knarly field access tracks Very Happy
Luckily, I'd previously ordered these Hankooks which came in from Germany and my local indie fitted / balanced them for £10 per tyre.
When I tried to source these locally I was told Hankook no longer did them. Mind you, that was after the guys gave me a blank look and said they'd never heard of the size before Laughing They're 305/40R22 114V and having only driven the car 10 miles since fitting them I'm already impressed compared to the Pirellis Thumbs Up They have an M+S rating so it should be interesting to see how they perform.
Not sure what you guys will think but personally I rather like the look. Just need too get the side bars off tomorrow - couldn't get in on the 2 post because of 'em Big Cry
Post #294780 22nd Nov 2014 5:45pm
i've always rated hankooks , nice job.. Thumbs Up ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #294783 22nd Nov 2014 6:01pm
RiccartonRR
Thanks Stan Thumbs Up
Post #294789 22nd Nov 2014 6:45pm
You can't beat new rubber, look the part as well... Thumbs Up Thumbs Up Pete
Post #294795 22nd Nov 2014 7:18pm
RiccartonRR
Thanks Haylands Thumbs Up
I think they look great from the rear - really fill the car out - but I'm too embarrassed to show a rear picture due to the Kahn stainless exhaust system the car came with Embarassed Everyone would laugh at me Embarassed Embarassed
Post #294796 22nd Nov 2014 7:31pm
Yep, sure would.... are you going to get it taken off??? Pete
Post #294798 22nd Nov 2014 7:40pm
RiccartonRR
Ermm dunno Embarassed
I much prefer the original understated look but the fact it is stainless and pretty well made makes it a difficult decision to make. Looks = crap. Longevity = excellent!
If I only approach the car from the front then it's fine Thumbs Up
When I bought the car I wondered why the tail pipes had been left to go black so I gave them a damn good polish. They stood out like a sore Censored !! I've let them go black again and don't stand out half as much.
I apologise to the FFRR gods for my crime Bow down
Post #294803 22nd Nov 2014 8:21pm
Weegie
Spray them black with heat resistant paint. Very Happy John
GAP iiD BT
Post #294805 22nd Nov 2014 8:44pm
RiccartonRR
Or cut the huge cast alloy ends off and replace them with tidy stainless tips that point downwards Very Happy
It'll be one of those impulse decisions which decides what I do Thumbs Up
Sorry to all sensible FFRR owners out there!
Post #294810 22nd Nov 2014 9:41pm
Googsy
You should get an alignment done also unless you want them going the same way as the Pirellis Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #294819 23rd Nov 2014 12:15am
RiccartonRR
Thumbs Up Thumbs Up
It's going in shortly for a service & will get alignment done at the same time.
Mind you, all Pirellis were worn evenly across with no feathered edges etc. The only uneven wear was on the front tyre with the wire sticking out through the 5mm of tread. This was due, in the main, to it going down whilst driving and damaging the point where the tread and the wall meet (both sides). Big Cry
I suppose I'm glad the NSF tyre did go down - this was the kick up the bum to get them changed. Otherwise who knows how long the delaminating OSR would have lasted.
Post #294827 23rd Nov 2014 9:46am
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
I'd would have stuck with Pirellis TBH we have no end of issues with Hancooks at work admittedly in a 17" size but each to their own
A consideration with this brand is availability often we struggle to locate especially if the car is away from base
Post #294834 23rd Nov 2014 10:49am
RiccartonRR
Supply is a problem - I've ordered spares to keep on the shelf just in case.
I switched from Pirellis as they didn't offer one for the 22" rim with a load rating greater than 106 which is way too low and probably explains why they always looked flat Shocked
The up-side of the Hankooks, purely by accident, was that when I finally found and ordered them they came in at £140 delivered per corner Shocked Shocked
Well impressed Thumbs Up
Post #294859 23rd Nov 2014 1:01pm
crispy2
Australia 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
As you say there, the 305 section does well and truly fill the guards out. How do they go for clearance on full lock? No rubbing I take it. Are the OF wheel normal offset and width?
Which Hankook tyre model were they?
Keen to hear your feedback to this.
Regards
Pete.
Thumbs Up '07 4.2 S/C
'13 X3M
Post #295895 29th Nov 2014 3:52pm
RiccartonRR
@crispy2 - They are Hankook Ventus ST RH06 305/40R22 114V XL. I can't help you with the offset on the OF wheels I'm afraid but they are genuine 22" Tigers so the info may be out there.
Before fitting them I heated the OS rear arch liner with a heat gun where it houses the fuel fill pipe and gained a good 10mm more clearance - not sure whether it was needed but did it anyway. I also fitted 5mm spacers to the rear - this and the arch liner mod were all recommended in another thread on here. Now I've got them fitted I can see there is no need for the spacers so when the wheels come off again so will the spacers.
As an update I can highly recommend them - they are that good even SWMBO has even commented how much better the FF feels to drive. Really positive cornering compared to the Pirellis, smoother ride and way less aquaplaning!! I know the cornering is probably down the the 114 rating and the smoother ride is the extra sidewall - any tyre of the same rating, not just Hankooks, would probably give similar results. However, there ability in standing water is impressive.
I've done a couple of very steep knarly tracks with them whilst towing 3+te and the grip was fine - absolutely no dramas at all.
You need to see them in the flesh - I must get some better pics - they are 2'5" diameter as well as being over a foot wide (305 profile) and look huge before they're fitted. Once on they look totally at home.
Sorry, will stop raving now Thumbs Up
Post #295924 29th Nov 2014 7:43pm
