Home > In Car Electronics (L322) > 2002 TD6 - Infotainment Meltdown |
Hi LB,
1st Dec 2014 1:31pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
You could try checking the 10A fuse on the top of the BM54, below the large connector plug.
1st Dec 2014 4:39pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7933 |
Well I've ripped the whole lot out of mine, head unit, BM54 DSP amp TV Sat Nav DVD and fitted the Android head unit and I still get the OBC data come up on the dash display when I press the end of the steering stalk, In which case I would imagine your problem has nothing to do with the units listed above.... Who knows what it could be then.... Pete
1st Dec 2014 7:25pm |
Lyndasbottom Member Since: 23 Nov 2014 Location: Devon Posts: 9 |
I'll try the one by one option as recommended and see what I get. The lack of OBC does seem to be a different issue but as I said before it's not clear where this info comes from or where it's stored. I have accessed the so-called "secret" menu on the display and things like mpg etc. are being stored but not being displayed. |
1st Dec 2014 9:06pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7641 |
Not sure about the OBC, but it's the sat Nav that drives the screen graphics.
1st Dec 2014 11:31pm |
The nav computer makes the graphics come out in a nice LR color scheme - but there are default graphics if the nav dies or is disconnected. LB had the nav disconnected according to his 1st post.
2nd Dec 2014 9:05am |
Haven't had a chance to do anything for a while other than take everything out but for the TV ready to put in one unit at a time. Had a spare 10 minutes this morning so put it all back in in stages and lo and behold I had sound!! The radio had stations and the tape worked. The CD cartridge is missing so no way to check that. Had a quick play with settings etc. and all fine. Didn't plug the satnav in as I'm sure that needs a software re-flash.
14th Dec 2014 6:19pm |
Try disconnecting the battery -ve terminal, reconnect, steering full lock to lock and see if your sound comes back on. |
14th Dec 2014 7:48pm |
No result disconnecting battery etc. Disconnected everything again and reconnected radio and DSP. Have sound again!! Leaving it until the morning to see if it stays working. Sounds good when it works. |
15th Dec 2014 8:03pm |
If it goes off again which it probably will instead of disconnecting everything try disconnecting the largest of the three plugs on the DSP and reconnect it and see what happens.
15th Dec 2014 9:40pm |
Well still have sound after a few days. I sprayed all the connectors with cleaner, dried them off and put it all back together and so far so good. Now it's stable I'll start connecting the other units back in and hopefully the faulty one will show up. Sending the satnav off for re-flashing and hopefully that will sort that out. |
17th Dec 2014 6:23pm |
18th Dec 2014 7:19pm |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
mine has not got that box and everything sound related works fine
18th Dec 2014 7:47pm |
The ff had the TCM which is the telephone control module and that voice recognition unit available as options.
18th Dec 2014 9:01pm |
