Home > Technical (L322) > tdv8 3.5 10 MY Not Starting on Cold Start cycle |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 483 |
Its taken me a bit of time to get to the bottom of this but i think i am getting somewhere now.
7th Dec 2014 7:42pm |
Sounds like fuel to me |
8th Dec 2014 6:37am |
thank you for replies
8th Dec 2014 7:13am |
The starting and then not running for more than a second or two says fuel starvation to me. If the glow plugs was an issue, the engine wouldn't fire or fire with lots of smoke. Although it could be that the motor management sees too many values out of wack (in case of a few bad glow plugs) and then stop running but I'm sure that would throw up fault codes.
8th Dec 2014 11:26am |
It's very seldom that glow plugs are required in our climate to start the engine, they do help when the temperature drops to just below zero but the engine should still start easily without them. I have only once waited on my glow plugs heating before starting the engine on my TD6 and that was when the temperature dropped to -17 °C |
8th Dec 2014 12:02pm |
i has just had a service where they (Matfords LR) added a diesel cleaner to the fuel, maybe that doesnt like the cold.
8th Dec 2014 7:54pm |
When the weather is colder the light will take longer to extinguish as it takes longer to reach its predetermined temperature.
8th Dec 2014 8:32pm |
i have not had an issue with diesel cleaner before just looking at options.
9th Dec 2014 8:34pm |
Hi James,
12th Dec 2014 7:11am |
food for thought, ok, thank you. not had the vehicle long though so dont know if it was a prior issue. its also not done it for the last week on any type of start! Cheers
12th Dec 2014 9:01pm |
anyone else had this issue, mines not done it since posting up, probably will tomorrow now! Cheers
6th Jan 2015 8:52pm |
Paddyc Member Since: 30 May 2016 Location: Antrim Posts: 13 |
Hi James
29th Dec 2016 10:55pm |
Hi James
29th Dec 2016 10:56pm |
yes i did it was the battery. even after fitting a new battery it struggled after a while.
30th Dec 2016 9:00pm |
