Home > Maintenance & Mods (L322) > Off-road height setting
scwilson
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Epsom Green
Actually, looking at my figures, I think I'll leave things as they are.
Taking an average ...
Front - Standard - 477 (manufacturer = 493)
Rear - Standard - 467 (manufacturer = 483)
Front - Access - 439.5 (manufacturer = 453)
Rear - Access - 437.5 (manufacturer = 443)
Front - Off-Road - 537.5 (manufacturer = 553)
Rear - Off-Road - 522.5 (manufacturer = 533)
I'm sure I didn't get exactly the middle of the wheel but the vehicle looks OK.
As Welshdragon mentioned "if normal ride height is -10mm than standard, off road and access height will be -10 aswell."
Does anyone actually have heights in line with these manufacturer standard ride heights?
Post #302895 5th Jan 2015 6:38pm
I wouldn't worry about those heights, it's close enough, they look a bit better sitting lower as well, if you don't do any serious off roading then it won't make any difference...
Well worth getting an IID tool or similar as the first time you get a fault with the FF (and you will!!!) it will cost over £100 at the dealers just to clear the code.
The convenience and ability to do code clearing and all the other things it can do is well worth the price... Pete
Post #302908 5th Jan 2015 7:05pm
scwilson
OK - thanks Pete. I do no off road, just want it correct but as you say, nothing to worry about.
I actually took some measurements at standard height but measuring from the bottom of the rim to the top of the wheel arch;
FRONT
Right = 749
Left = 748
Not the expected 767
REAR
Right = 749
Left = 744
Not the expected 757
I am wondering ... the previous owner had the standard 19" wheels replaced with 20" wheels. Silly question, but would the suspension need re-calibrating for that?
Lastly, if it's worth me purchasing an IID tool or similar, can you or any of the other experienced owners on this forum recommend a good one for me?
Thanks to all on this forum, really appreciated!
Post #302926 5th Jan 2015 8:12pm
my height specs are pretty close and tbh as long as the front is 1cm higher than the back then it will be ok...dont ask why the front is higher as nobody seems to know Confused ..
@mr wilson , your heights wont need re-calibrating if you switch from 19 to 20 inch wheels.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #302927 5th Jan 2015 8:14pm
scwilson
Thank Stan - good to know.
I wonder if the EAS computer is clever enough to tell you if the heights are off or whether it only tells you of major problems, for example, compressor failure etc.
I'll look into some IID tools.
Post #302931 5th Jan 2015 8:28pm
miggit
The EAS computer is only clever enough to swear at you and tell you it's gone Pete Tong, self diagnostics and error correction is what the stealers were designed to do Rolling with laughter
Your height difference is down to the height sensors getting bashed about, and getting old. If it goes up and down, and doesn't look like a dragster and it's not dragging it's bum, leave it alone! Once you start to fix little annoyances it will bite you in the butt and cost you big time Wink IF IT AIN'T BROKE, DON'T FIX IT Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #302953 5th Jan 2015 9:27pm
