Home > Maintenance & Mods (L322) > Pyrotechnic removal
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Pyrotechnic removal
presumably its pretty straight fwd to remove? just strip it and take reconnect the wires straight to the terminal? Cheers
James
Post #303507 7th Jan 2015 10:06pm
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Disconnect battery?......................maybe as a precaution Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #303515 7th Jan 2015 10:21pm
Why would you want to JST?
Post #303531 7th Jan 2015 11:06pm
The pyrotechnic device is fired from the airbag system. If you simply un-plug the connector to it it can't fire.
I have no idea if this connector is monitored in anyway by the airbad ecu or what the implication is of removing it but I suspect it may be nothing.
On the face of it I think you could safely remove it and simply connect the battery cable direct to the battery terminal but as above I'm not 100% sure. You could always try it and see.
I would certainly disconnect the battery before doing anything. Thumbs Up
Post #303534 7th Jan 2015 11:15pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
+1 with Craig here - it's part of the safety system. It should not be bypassed or removed?? Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #303535 7th Jan 2015 11:16pm
johnboyairey
If you need a spare one for 2002-2006 type, I have a new one I bought to fix my airbag fault. Not needed etc.
Post #303539 7th Jan 2015 11:23pm
JST
was looking to split wires for the VSR i intend to fit.
looking again today, the pyro only works on one wire - which wire is that? or where does it go.
i have three other wires coming into the battery there, anyone know how to identify which is Alt/Starter and what the others are? Cheers
James
Post #303665 8th Jan 2015 6:12pm
