Home > Maintenance & Mods (L322) > Replacing Door Aperture Seal 2005 SC
SO3isme
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
I have bought a new drivers door rubber seal as the existing one is a bit frayed at the bottom. Does the old one just pull out? or is there more to it?
Thanks.
Post #303672 8th Jan 2015 6:46pm
There is at least 4 rubber seals on each door sir Whistle
Which one are you referring to?
Post #303684 8th Jan 2015 7:26pm
SO3isme
It's the one on the body that goes around the door frame. I think they tend to wear as they get trodden on.
Post #303685 8th Jan 2015 7:29pm
Still slightly confused my friend... As you should not be able to tread on it as you have Aluminium tread plates sir Whistle
Post #303690 8th Jan 2015 7:34pm
SO3isme
Hope this pic helps....
Post #303699 8th Jan 2015 7:59pm
Right... Couldn't remember it sticking out from memory...
OK, remove the Ali sill plate (screwdriver underneath and jemmy it up) then you can pull (towards you) the kick panel around the bonnet pull... Remove the B pillar trim (to allow the black trim below it to be removed) 2 pop out trim pegs in the top... THEN>>> you can finally remove it and replace Thumbs Up
Its quite a lot more involved then at first glance sir... Rolling Eyes
Post #303759 8th Jan 2015 10:48pm
SO3isme
Thank you -'knew it wouldn't be the easiest.....
Post #303765 8th Jan 2015 10:53pm
How much was the new one please?? my drivers one has seen better days.... Pete
Post #303768 8th Jan 2015 11:01pm
SO3isme
£48 from Duckworth - Dan's the man Smile
Post #303769 8th Jan 2015 11:05pm
Blimey, that's cheap, father in law wanted one for his Toyota Corolla and it was nearly £100...
Got some stuff coming from Dan already this week... I'll wait till next week...!!
Thanks for that.. Pete
Post #303772 8th Jan 2015 11:15pm
Good luck my friend... Thumbs Up
Post #303795 9th Jan 2015 1:09am
SO3isme
Done! Not as bad as I was expecting. The replacement seal was about 5cm oversize so I had to cut it down. I was worried by this, but I double checked it was fitted fully into the corners all around first. I used a block of wood covered in some rag and tapped it into the awkward spots. Only needed to pull the trim aside apart from the treadplate. The hardest part was getting the treadplate back into position as the clips had moved.
Post #304206 11th Jan 2015 3:23pm
Thumbs Up Thumbs Up Thumbs Up
Post #304308 12th Jan 2015 12:11am
Looks much better, why have you got two mats in there??? Pete
Post #304346 12th Jan 2015 10:34am
You shouldn't have to cut the new seal, are you sure you fitted it tightly into the corners?
Post #304373 12th Jan 2015 11:48am
