Home > Technical (L322) > Bl00dy FBH again
Page 1 of 3 123>
JAYBOY
Bl00dy FBH again
Evening all. PLEASE HELP IF YOU CAN
My car went into Land rover in December as the FBH wasn't working. They had it for 4 days changed the whole system and the fuel supply pump. Shocked So i was told. I picked the car up and tried it, I was sure that it wasn't working as no smoke or any fumes were coming from the car. The head Tech came out and said it fine sir we've had it working and ushered my on my way. Whistle I thought i would give it a try over the festive period, so on a -4 morning i tried it. Guess what Banging Head Banging Head
So i rang Land rover and booked it back in. Took the car down on Monday and they have called me today. Shocked
Sorry sir we have changed everything and we can't get it working we are stumped.
Are there any superior beings amongst us that can shed some light on this for me please.
Thanks all for reading my rant.
Jay 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #303469 7th Jan 2015 7:41pm
PM LR customer relations on here and ask them to intervene, there should be some master tech then can send to have a look, even heard of them sending the car back to the factory to get fixed....
Just insist it's sorted.... Pete
Post #303473 7th Jan 2015 7:58pm
JAYBOY
Cheers Pete
I will call Mike or is it Ryan now in the morning. 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #303476 7th Jan 2015 8:00pm
Sandyt
Not much good suppose but they had mine in in December changed the pump but there was a blockage in the fuel line or I should say one of them which prevented it from working also mine shows no fumes whatsoever when running but it does get warm - good luck
Post #303559 8th Jan 2015 1:24am
They need to check the FBH is actually working when tested directly. The webasto's are easy to do this to as they are simple devices. From there they can then trigger it from the SDD/Testbook (IIRC) and make sure the main control unit for the car is actually sending the signal out.
It would not surprise me if from what your saying, that the unit has been marked in the CCF as not being present.... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #303573 8th Jan 2015 3:35am
Re: Bl00dy FBH again
Jay
Jay, is yours still under warranty then?
Post #303612 8th Jan 2015 11:45am
JAYBOY
Craig
It is sir.
I have called the dealership this evening for an update.
They have said they are still working on it.
I asked if they have a master tech working on it as the system is not that complicated. he replied with yes sir he thinks it could be the battery. So i said change the bl00dy battery to see if thats the problem. he replied with everything takes time with this process. they have now had the car for 7 working days and still no joy. Banging Head Banging Head
I think the battery could be the cause because they did have it working at some point. If they had had the car on a charger pack it would probably work. It can't be that hard CAN IT 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #303668 8th Jan 2015 6:24pm
martinf
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
I had a problem with my FBH on my 2010 Vogue.
It went in a couple of times but still didn't work. So I pressed my dealer to sort it before the warranty expired.
It turned out that water had got into the electrics under the passenger seat as one of the sunroof drain tubes had not been properly located when the car was built. The result was replacement of a substantial part of the wiring. It took their top technician a full week to do the job.
I hope this is not your problem as the cost of the warranty claim was huge.
Post #303693 8th Jan 2015 7:39pm
sass
Finland 2003 Range Rover HSE Td6 Adriatic Blue
The FBH on my ´03 TD6 does not switch on even at temperatures below -10 celsius. Previously I was mistaken that "Pre-heating" indicated FBH as the message would appear when the ambient temperature was below +5 celsius.
My iCarSoft 930 recognizes the FBH and everything appears to be OK with it, it is just not switched on. Pulling the FBH fuse makes the FBH "disappear".
According to the seller (the previous owner, an independent LR garage) the "brain" of the FBH should be replaced with a generic unit, as the LR-spec'd units are prone to failure. There is also a possibility that the car does not send a signal to the FBH for a reason or another. Don't know if this is true.
The FF itself is a Belgian imported HSE without the remote unit for the FBH.
The motor thermostat was changed less than a year ago by the garage. Since the colds started in late December, the temperature gauge does leave the blue section but seems to stay just above it even after longer runs. This is also my first winter with a FF.
Do you have suggestions?
Post #303865 9th Jan 2015 3:09pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
they can all be tempremental because they dont run for long enough (30 mins is not long enough to get rid of the carbon build up in the burner chamber) they are connected to temp senders ect and have there own failsafe shutdown system if anything is wrong,they are also very voltage reliant.
when they are on boats for central heating they run for 5-10 hours at a time and need very little maintance and last for years because usally all they have is just an on/off switch and non of the car assosiated crap to interfear with.
landrover/bmw ones are just harder to bench test because of the k-bus from the car needs to be connected to start it up.(data not voltage)
a diagnostic tool can be worth its weight in gold with these because you can test every componant on the FBH WITH IT STILL ATACHED TO THE CAR. also you can force it to work using these things proving if its the heater or the car thats at fault
they are very complicated bits of kit to people/dealers who know nothing about them, but once you can get your head round how they work and run a few simple tests with a multimeter and a stop watch can diagnose what is wrong with them and usaly its a simple fix becase all the parts are still available and also the control boards can be sent away tested and repaired fairley cheepley.
you will have to start with checking the temp sender behind the grill and bypassing it,also connectors/wiring to the FBH its self
BUT START WITH THIS
read how the ff heater is suposed to work
fullfatrr.com Wiki > FBH
then read RAVE manual
you will once again see what its suposed to to and what talks to what to make it start and run
once again read and digest these posts ,the cars might be different but the heater and operation is very much the same
http://www.the75andztclub.co.uk/forum/showthread.php?t=71982
http://www.the75andztclub.co.uk/forum/showthread.php?t=100297
make sure the battery is fully charged and kept charged then and only then start the diagnostic checks
take a special note of french mikes checks
take your time dont skip anything
and also
let us know how you get on
nige
Post #303884 9th Jan 2015 4:57pm
JAYBOY
Update
Chaps
An update on the car.
I had the car back and it did work for a couple of minutes and turned itself off.
So it went back in to the dealers.
They kept it for a few days and said it fine after they changed the battery.
So off i trotted and picked it up. Took the car home waited a few days for a really cold morning and guess what no FBH.
I rang the dealers and showed them my lack of faith in them having it back a fourth time.
They assured me that they could Fix it.
So they picked the car up last Tuesday and they have put one of the master techs to work on it, to be fair he rings me a couple of times a day with updates of what they are doing.
He's been really good and at one point had it running for a full cycle and smoked the workshop out.However he has only managed to get it working once in four days.
They have wiped the cars programs and installed all new changed the battery again to one of the new types. Could be a gel one.
Driven it 20 miles locked it up for 4 hours after a software update.
They are now going to trace all of the wiring to see if the problem is that.
They have changed the whole system more than once.
In the mean time the weather is bloody freezing and I'm driving the defender everywhere.
I hope they can sort it next week.
They have had the car now a total of 17 days and I'm still none the wiser. Big Cry Big Cry Big Cry 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #307739 24th Jan 2015 10:16pm
Don't they make US look good Jay Whistle Whistle Whistle Wink Thumbs Up
Whistle Whistle Whistle Thumbs Up
Post #307765 24th Jan 2015 11:13pm
JAYBOY
Bow down Bow down
If they can't fix it next week i will have to have a rethink.
Its only done 24K so i will ask Land rover to intervene. 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #307774 24th Jan 2015 11:33pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
I have the batteries in my fob the wrong way round for 11 months of the year so my FBH doesn't run by accident....it's not that complex a system so I'm a tad confused by LR struggling so much Rolling Eyes Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #307777 24th Jan 2015 11:35pm
Don't know how they stay in business Jay...
I can only presume you are NOT a priority as its poorly paid warranty work Whistle Whistle Whistle
Post #307780 24th Jan 2015 11:37pm
Page 1 of 3 123>
