Home > Maintenance & Mods (L322) > Name that tune. Engine squeal sound. (Video attached) |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 860 |
So my Range makes a squeel sound. Or maybe a flutter is better description. It's not steady it will squeel for a second, then not for a second or two then do it again. I attached a video that tried to capture it. Is this a fan belt, tensioner, pulley, issue? I have a 90 day warranty from the LR dealer on engine and trans but it expires in a week or two so I need to know of this is something major.
12th Jan 2015 8:16pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Can't hear any squealing?? .
12th Jan 2015 8:58pm |
you don't hear it? Its like a fluttering or something rattling that's loose. |
12th Jan 2015 9:21pm |
Chirping does sound about accurate. It's intermittent and each instance is is not the same duration. I don't have a SC so possibly a belt. Hmmm. How hard/cost was it to switch the belt out? |
12th Jan 2015 11:03pm |
The oil leak was a warranty job and the belts were replaced within that process. I'm sure someone will give an indication as to parts and labour costs if the forum search engine doesn't help.
12th Jan 2015 11:23pm |
