Home > Technical (L322) > Tv screens in headrests...
Andy
How easy is it to fit them and can they be linked to the TV so that rear seat passengers can continue to watch TV whilst the car is in motion. If they can be linked up, what is involved?
On that note, can the TV be adapted so that it continues to broadcast whilst driving for front seat passengers benefit?
Post #3060 24th Feb 2009 2:32pm
you can get the tv to play on the front screen with the addition of a cable. its the same system as in BMW's, I had it on my M5 and it takes about 5 mins to fit. i got one 2nd hand for £100 a few years back. You can get them on eBay new now for less.
http://cgi.ebay.co.uk/BMW-RANGE-ROVER-TV-P...240%3A1318
Do some searches for tv in motion bmw for fitting it etc as below.
eg.
http://www.bimmerfest.com/forums/showthread.php?t=50956 Discovery 4 HSE
Post #3064 24th Feb 2009 3:25pm
Andy
Nice one, cheers. Where is this plug that has to be disconnected- under the dash or in the rear of the car?
Post #3066 24th Feb 2009 3:48pm
in the boot, left hand side cover, some are in the spare wheel well. follow the bimmerfest link above and you can identify the parts. Plus, the one on ebay will come with instructions. Discovery 4 HSE
Post #3068 24th Feb 2009 4:04pm
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Try NaVTV thats what I got beware there are different ones for different model years
Post #3069 24th Feb 2009 6:29pm
Andy
Ok- so how do the headrest TV's connect to the main system? Is there a wiring loom we can buy or something?
Post #3071 24th Feb 2009 8:16pm
dantheman
I've thought about this myself a little - and surely there must be a mod out there somewhere...
Although I've not looked into it yet, surely someone on here is ahead of the curve!
Post #3082 24th Feb 2009 11:31pm
Andy
This was also on the bimmerfest forum. Can anyone confirm that it works on RR's?
Watch TV / Videotext during driving
This works on all 5/7 Series with the Mark I Navigation System (the one with the male voice).
On Mark II (the newer version with the female voice) you have to use "brightness" instead of contrast for TV and "color" instead of brightness for videotext to get the trick to work.
This works on the latest 99 7-series models as well. This does not appear to work for the latest BMWs sold in Europe (2000 onward, 3/5/7 series). The software updates for latest navigation CD-ROM's do not appear to affect or disable this trick.
1. set ignition to pos. II
2. enter TV mode
3. enter "settings"
4. enter "contrast"
5. when the green contrast bar is visible, push the knob and keep it pressed
6. turn ignition off (keep button pressed!)
7. wait 8-10 seconds (timing must be accurate!)
8. release the knob
9. turn on ignition again
Now the TV will operate while the car is in motion, though you certainly should leave that to your passengers only while driving. To watch videotext use the same procedure as above, but choose "brightness" instead of "contrast"
Post #3162 27th Feb 2009 9:55am
Andy
Update:
Just tried the above- doesn't work Sad 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #4204 26th Mar 2009 12:16pm
ambishop
2003 Range Rover HSE 4.4 V8 Chawton White
You need the TV in motion module for this to work OR there is a software tool called NAVCODER that you can download and connect to your RR using a coding tool http://www.reslers.de/IBUS/
navcoder
http://www.x5world.com/navigation-system/4...eased.html
Will need to make an adapter for it to connect to the RR or pull out the cd changer from the glovebox which is a 2 hour deal to pull out and get back in
Here are instructions for removing the CD changer http://www.roverupgrades.com/Range_Rover_MP3_Cd_Changer.html
Post #4544 5th Apr 2009 12:26am
