Home > Technical (L322) > Bl00dy FBH again |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 |
DMRR
24th Jan 2015 11:55pm |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 |
Is it getting fuel?
26th Jan 2015 8:48pm |
Steve
26th Jan 2015 8:55pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
On the plus side the weather is improving, so you won't need it by the time they get the vehicle back to you Land Rover Addict
27th Jan 2015 9:59am |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 539 |
Seems there would be a great opportunity for someone on here that could take our cars and sort out these FBH problems, surprised no one has offered their services
27th Jan 2015 5:08pm |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
there are no takers
27th Jan 2015 6:34pm |
Ningr Member Since: 20 Jun 2014 Location: Towcester Posts: 63 |
These units seem to be similar to the units used on our diesel trains.
27th Jan 2015 8:47pm |
Still no car
1st Feb 2015 9:29pm |
B100 Member Since: 06 Jun 2017 Location: Bedfordshire Posts: 25 |
I know I'm four years late on this, but somebody may be able to make use of what I have discovered. The FBH will only work if the battery voltage is high enough - otherwise there is a risk the FBH flattens the battery and you won't be able to start the car. Yes - I guess you already know this. I presume that the heating designers have erred on the cautious side and set the voltage threshold on the high side.
13th Feb 2019 11:55pm |
Norway Member Since: 09 Dec 2012 Location: Høvik Posts: 123 |
How did this end? -03V td6
17th Feb 2019 12:37pm |
Mine is not kicking in at the moment. I’m going to put the car on the Ctek tonight to see what it’s like in the week. I guess that the voltage is a bit low. There is nothing that can't be fixed with a hammer😜😜
17th Feb 2019 1:02pm |
You can do a simple basic check. Use a battery charger to be certain the battery is fully charged. If the FBH is OK, then it should start and run with no problems. If it won't start, then there are only three possibilities: the battery is on its way out, the FBH is faulty, or there is no fuel supply to the FBH. My experience of Webastos is that they are very reliable - apart from the water circulation pump. Give them fuel and a 12v supply and they invariably work fine. If it starts and runs for just a few minutes then shuts down, put your hands on the heater pipes to see how hot they are. If they are hot, then the chance is the water circulation pump has failed. The built-in temperature switch will have detected the water getting too hot and will shut the heater down. |
17th Feb 2019 1:24pm |
It was the battery. Land rover admitted they had a bad batch of batteries, they had changed mine three times.
17th Feb 2019 8:48pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Guys don't forget the FBH won't work if fuel level is too low.
17th Feb 2019 9:07pm |
