Home > Technical (L322) > 02 4.4 v8 gear box problems.
timc20xe
England 2002 Range Rover HSE 4.4 V8 Adriatic Blue
Having problems with my range rover. Started the other day it went in transit fail safe mode . Now my car won't even move . Put it in reverse or drive and it just chucks it self forward and stalls . Even with foot on brake it chucks it self forward . It's like sitting on a motor bike and knocking it in gear with out using the clutch .
Car wouldn't even start today as it had a flat battery for some reason so I put another battery on and it started but is running very ruff and won't idle and now says air suspension inactive.
Post #310906 5th Feb 2015 5:41pm
timc20xe
Post #310908 5th Feb 2015 5:43pm
when you put the new battery on did turn the steering fully left and then fully right to set the steering parameters? ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #310910 5th Feb 2015 5:44pm
timc20xe
Nope didn't no about that . Should I disconnect the battery then re connect and start again. ?
Post #310917 5th Feb 2015 6:05pm
as a starting point i would, details how to do this are in our wiki... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #310919 5th Feb 2015 6:15pm
andrew.aa
Italy 2004 Range Rover Westminster 4.4 V8 Java Black
hi, I do not know to open a new thread, or continue here.
the diagnosis of my EGS transmission ZFHP24 is follows,
https://drive.google.com/file/d/0BwuJIrNHq...yYlJB/view
but I do not understand what it means Shocked . Could anyone please help me.
thanks
Post #314603 24th Feb 2015 1:04pm
Can't read German but I think it's telling you something about a defective solenoid in the gearbox, take it to a gearbox specialist and get them to check it...
The can-bus fault is a pretty standard fault on most of our cars and isn't anything to worry about... Pete
Post #314653 24th Feb 2015 8:16pm
RRPhil
thanks
Are you able to disconnect the 16-pin electrical connector at the rear of the transmission and measure the resistance between pins 4 & 16 ?
Phil
Post #314691 25th Feb 2015 12:25am
andrew.aa
thank you all for the help and thank you Phil, Thumbs Up
I have tried to measure between pin 16 and 04, although really hard work. Twisted Evil
no there is a different location to make this measurement, for example to the pins of EGS?
in any case it seems that the solenoid is not interrupted, but I do not understand how to measure the ohms with my digital meter. even with that professional multimeter
My video shows the shift motor potentiometer test done few days ago, but the same tool between pin 16 and 04, always shows me 00.0
I homemade two female probes,to be sure insert on pin 16 and 4 correctly
As I told you Phil long time ago,the reverse problem is still present, after gearbox oil warm (Failed F clutch piston seal, I believe), and Lip home mode came out for another cause, so I think reverse problem is an independent failure
I was thinking also for the TCASE shift motor, that sometimes 'TRANS. FAILSAFE' is displayed, and is not related to the oil temperature, but as can be see seems to be ok
first time i solved with fuse 37 procedure, but now this procedure can't be done and low range can't be inserted.
I have now deleted the all errors and EGS adaptation value, and I'll do a test on the road to see what will say next diagnosis
Post #314806 25th Feb 2015 6:00pm
RRPhil
The winding resistance of the three shift solenoids (Magnetventil) should be between 26 and 30 ohms whereas the resistance of the rotary potentiometer in the transfer box shift motor is measured in kilohms. Perhaps you have the wrong scale selected on your meter?
The ‘Magnetventil 3’ solenoid’s only job in life is to activate should the driver accidentally move the gear lever into reverse while the vehicle is travelling forward at speed. In other words it’s likely that it never gets called upon during the whole lifetime of the vehicle. When activated by the controller the solenoid pressurizes the opposite face of the reverse gear valve (RG-V) spool - thereby preventing engagement of the C & F clutches. The solenoid does however get pulsed ‘on’ when in Neutral.
If it’s easier for you to measure the winding resistance of the solenoid at the ECU you need to measure between pins 16 and 21 on the C1835 connector
Phil
Post #314895 26th Feb 2015 12:01am
andrew.aa
This morning I tried to do the test again, through C1835 connector at Transmission ECU as follow image
https://drive.google.com/file/d/0BwuJIrNHq...sp=sharing
unfortunately the same result: 00.0 Embarassed
gray tool is a digital Clamp meter and has only 200kOhm scale
and the blue one has different scales but value is always 00.0 again
where is my error?
Post #314938 26th Feb 2015 10:42am
Rovertech
United States
This is going to sound stupid, but bear with me. Try turning the key on (position 2) for 60-90 seconds, then off, then start the car, turn the steering wheel lock to lock.
There is a memory calibration function that resets if you do this procedure.
Post #314972 26th Feb 2015 2:53pm
RRPhil
As you’re only trying to measure 30 ohms you need to set your blue multimeter dial to ‘200’ but if you’re still getting a measurement of zero then this shows that you have found your problem i.e. a short somewhere in the solenoid circuit. As you were also measuring zero ohms at the 16-pin connector on the back of the transmission (between pins 4 & 16) this indicates that you have a problem with either the transmission wiring loom or with the solenoid itself.
Sorry to say that your next move therefore involves draining the transmission fluid and removing the sump and then measuring the resistance directly across the terminals of the MV3/SV3 solenoid (sorry about the confusing use of both terms – in German it’s Magnetventil (MV), in English it’s Solenoid Valve (SV)) to determine which is at fault.
Phil
Post #314996 26th Feb 2015 5:28pm
andrew.aa
Today I tried to do another electric test, before drain the transmission fluid, and remove oil pan. Big Cry
So I tried to measure the others Solenoids at C1835 CONNECTOR, as image below ,
and all results are the same.
between : pin 21 and 38,26, and16 always 00.0
this result mean that wiring are good because are not interrupt, but as you think Phil, there is something like a short circuit somewhere.
The only strange thing is that transmission work properly and with solenoid short, I believe the transmission can't work
So, I think there is something else and.. what can I do Phil? Idea
Post #315928 3rd Mar 2015 2:26pm
andrew.aa
update
After many tests, I believed my multimeter be damaged, so I bought a new professional multimeter, and as I imagined, the measure was shown exact, respectively 27/28/26 ohm
my apologies to all, Bow down
So , now seems to have good solenoids. Thumbs Up
Post #315947 3rd Mar 2015 3:58pm
