Home > Technical (L322) > engine system fault TDV8
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
Afternoon all
Just jumped.in the rangey to move it, and engine system fault pops up only for a second and then disappears....press the check button and everything shows ok, it's done it twice in half an hour. Now on charge, just in case battery is a bit low.
Any ideas?
Post #312616 14th Feb 2015 5:22pm
SFM
Forgot to mention, although it's only done 5k since service, the service date is flashing up also, and has been for a while, are the two connected?
Bit miffed, as my Indy didn't reset service schedule obviously.
Post #312617 14th Feb 2015 5:34pm
Battery, then top turbo hoses as a place to start. As these are easy to access, replacement instruction in the wiki. Take them off and check for cracks or splits, especially under the protective mesh.
Then get the codes read as these will point out what it is, the check control won't show anything bar low washer fluid and bulbs blown really. There is nothing that can't be fixed with a hammer😜😜
Post #312621 14th Feb 2015 5:45pm
SFM
NMJ
Would a faulty hose throw up a fault on start up, as soon as engine runs, fault disappears?
On charge at the moment, tomorrow I will give it a thrash, and see what happens (or blows up)
I am starting to get fed up with this thing now, every time you turn the key, you are waiting for the dreaded bloody BONG!
And another £1000 + Big Cry Big Cry
Post #312635 14th Feb 2015 6:42pm
If it's doing it at start up when cold it could be the start of an EGR issue! Best not to cane it I case you do damage to the turbos... Get codes read asap my friend...
Post #312637 14th Feb 2015 6:48pm
Craig has a point, and is more likely the problem, but worth checking the easy stuff first.
But get the codes read and it will point you in the right direction. Otherwise you are just guessing. There is nothing that can't be fixed with a hammer😜😜
Post #312641 14th Feb 2015 6:55pm
Exactly... Hopefully it will be a pipe split BUT!!! Don't cane it, that's important Thumbs Up
Post #312643 14th Feb 2015 7:02pm
SFM
If it is something like the egr, will it not go into failsafe mode?
Post #312647 14th Feb 2015 7:29pm
Err, no...
Will just go bang 🙈🙉🙊 There is nothing that can't be fixed with a hammer😜😜
Post #312655 14th Feb 2015 8:39pm
In a BIG & expensive bang!!!!!!!
Post #312660 14th Feb 2015 8:54pm
SFM
That's reassuring to know
Post #312663 14th Feb 2015 8:57pm
Fault codes read my friend... Egrs are reasonable, turbos and ingested vanes are not. There is nothing that can't be fixed with a hammer😜😜
Post #312665 14th Feb 2015 9:00pm
SFM
Thanks guys
See what happens tomorrow, after a night on charge
Post #312671 14th Feb 2015 9:16pm
SFM
Battery now fully charged again, started her up...no faults
Went for a 25mile drive, all good. Hopefully it was just the battery a bit low, my wife has been using the heated seats and wheel a lot lately.
Fingers crossed, this is all it was.
Post #312770 15th Feb 2015 12:21pm
Sql
Poland 2007 Range Rover Vogue TDV8 Buckingham Blue
Did you ever get to the bottom of it? My tdv8 started to show "engine system fault" message at first morning start for a brief moment. After a second or two it dissapears and does not appear again throughout the day. 07 3.6 TDV8 Vogue
Buckingham Blue / Sand / Piano
Post #424887 26th Jan 2017 4:18pm
