Home > Maintenance & Mods (L322) > Why is my SC " System too rich " Engine Management
ebajema
That is a good start Ryan, the injector cleaner should do a good job of cleaning your fuel system internally if you use it for a while.
Once you confirmed that there is no false air etc. or other issue causing (loose vacuum hoses ???) the problem, then you can decide to go in deeper and clean the inlet manifold etc. MY 2010 5.0 SC Galway green and sand interior!!
Post #312724 15th Feb 2015 8:02am
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
There is a TSB from LR on this issue - they recommend the use of BG44K fuel cleaner. I used it on my SC when I had it and it worked a treat. You are only meant to use it once a year though. Thumbs Up Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #312727 15th Feb 2015 8:23am
pld118
Thanks CG.
From a bit of online reading, it seems that mainstream off the shelf fuel cleaners/ additives are a myth in so far as there are many who suggest little to no evidence they work in any way, including a historic AutoExpress review article.
BG44K does seem to be one of the few that people think has a benefit although it seems to be something you can only order online.
Post #312730 15th Feb 2015 9:19am
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Should be able to get a can of BG44k at your local Kwikfit Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #312743 15th Feb 2015 10:38am
Amazon = two days to deliver
Post #312744 15th Feb 2015 10:40am
pld118
Thank you Thumbs Up
Post #312748 15th Feb 2015 10:54am
pld118
Good idea nicksaab, the local Kwik Fit has it in stock for £20/can.
Post #312752 15th Feb 2015 11:07am
