Home > Technical (L322) > L322 not warming up |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Is it actually doing anything wrong. Diesel engines are quite efficient and if you're going down a long hill in cold weather with the heater on aren't you going to cool the engine?
24th Feb 2015 11:51am |
Well, there's no thermostat on the heater circuit, so if you have the heater on full and are coasting down hill you will be cooling the engine even though the thermostat may be closed, and with my car when it is cold it does just that. Not much the thermostat can do about it, simple laws of thermodynamics.
24th Feb 2015 1:56pm |
GregoryT Member Since: 13 Feb 2015 Location: Limassol Posts: 11 |
Will investigate further and revert./Thanks |
24th Feb 2015 2:02pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
When I had my gearbox changed the company that fitted it also fitted an external gearbox oil cooler, they bypassed the oil cooler by joining the redundant water coolant pipes togeather, effectively bypassing the main engine thermostat.
24th Feb 2015 2:08pm |
That might be an area to look into as well. Have fitted a new/original gearbox cooler as well on this car. Supposed to have its own thermostat inside to cater for just that. will try and block the return pipe and see it it changes anything although not a good practice as these gearboxes 5GM don't like running cooled. |
24th Feb 2015 2:18pm |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1227 |
Just trying to tackle the same issue on my car. I have replaced the EGR valve and EGR thermostat and but the temperature gauge still drops to just over blue on motorway journeys.
7th Apr 2018 11:57am |
Flashman, it's almost certainly the EGR thermostat. That was the problem with mine - not the egr valve, but the egr thermostat. It's simple and cheap to replace, so I would do that as the next step.
8th Apr 2018 9:01am |
Thanks Kurt, already done it. Whilst the main thermostat is the next one to tackle, some on here have had issues with the oil one. I just wanted to know how easy that one is to tackle as I would ideally like to do it myself if needed. Tom
9th Apr 2018 2:21pm |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 |
Sorry, can't help with the oil thermostat, didn't even realise it had one - just a cooler!. I had similar probs, EGR thermostat was fine and I cured it with the main water thermostat.
9th Apr 2018 8:38pm |
