Home > LPG > LPG problem, advice appreciated |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 |
The solenoid valve at the vaporiser will likely be gummed up and stuck - it get's sticky with the LPG residue and needs cleaned.
25th Feb 2015 8:46am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
They have a computer control for them, if you can't find the fault then get it code read by an LPG installer, should tell you whats wrong... also, check you didn't disturb anything when changing the filter... Pete
25th Feb 2015 9:39am |
Knightrider Member Since: 22 Mar 2014 Location: England Posts: 125 |
I was thinking to try disconnecting the battery for 30 mins or so to reset the ecu - is this worth a try or will it wipe all the settings off the LPG ecu and cause more potential problems? 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast |
25th Feb 2015 4:16pm |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
should be a fuse for the LPG system just pull that for a reset
25th Feb 2015 5:10pm |
You can't wipe the LPG ECU by disconnecting the battery...
25th Feb 2015 7:46pm |
Thanks for the advice, I tried the battery disconnection anyway buy the fault is still there, I will take the car to a LPG specialist on Saturday to hopefully resolve the issue, will update you guys once done. 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast |
25th Feb 2015 11:02pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 785 |
Have you checked your coolant level ? If t's low then the vaporiser will not get warm enough to unfreeze the gas . |
26th Feb 2015 7:49pm |
Hi yes that was one of the first things I checked, coolant level was fine. I'm taking the car in to Save LPG in birmingham tommorow to hopefully get to the bottom of this. 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast |
27th Feb 2015 10:51pm |
Hi quick update took the car to Save LPG Ltd in Birmingham today, the fault code was showing as no pressure and it turned out to be a blocked valve at the back near the tank. Good call CG-SC you were right but it wasn't the valve near the vaporiser. The valve was removed and replaced with one that is thinner and less likely to get blocked with 'dirty' gas. Cheap straightforward fix in the end, recommend Save LPG guys to anyone in the midlands they know their stuff and offer good value service. 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast |
28th Feb 2015 9:10pm |
Glad you got it fixed, I was fairly sure from your symptoms that it would be a stuck solenoid - it is usuallt the one at the vaporiser that gives issues - if it happens again I'd look there......fingers crossed all will be gine though Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
3rd Mar 2015 6:46pm |
